Question about Dell Computer Refurbished SYSTEM BOARD - OPT GX280 SFF FOR OPTIPLEX GX280 SFF Computer (H5354) Motherboard
Power off issue for GX280
I have a gx280 dell and when i try to shut down the box via Windows ''turn off '' computer click button Windows logs out says it is shutting down but never completely finishes - it sits at a grey-blue screen and the cpu fan revs high and stays that way -
you can turn it off by holding the hardware button down for a couple of seconds- but the box will not shut down through Windows
any ideas ???
    Problem Solver:
  • 9 Answers
Just run scandisk for your windows driver and check for any errors.
i once got this problem i just ran scandisk and some errors are found in the filesystem and they were removed
after that i have no prob shutting down my pc.
and if possible try to run a virus scan like avast or avg. etc.., this could take long if you have a monster harddrive and data.
hope this helps..
Posted on Apr 19, 2009
Dell gx280 one beep then keyboard goes dead
The only thing I can think of is that you might have some muck under the keyboard. See if you can get someone to clean out the inside of your keyboard. Hope this helps.
Mar 21, 2014 | Dell OptiPlex GX280 PC Desktop
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
Can not find jumper switch for Dell GX280 to remove password.Where do I find it or is there another way?
Hi there, For the GX280, you don't use a jumper to reset the BIOS password. You can reset the BIOS by pulling out the motherboard battery. The battery is on the opposite side of the external ports, and is flat and silver.
Power down and unplug the computer, then remove the battery for 10 seconds. Put the battery back in, then power up the computer. There should no longer be a password. If it is a Windows password you are talking about, you will need to reinstall Windows. Please let me know if that is the case. Alex
Jun 04, 2011 | Dell Optiplex GX280 (99301) Motherboard
Have a dell gx280, shut it down last night and this morning the normally green start up lite was flashing amber. after looking at some forum most replied with either replacing the mb or power supply which...
It's a pretty common issue with the 270 & 280. More times than not it is blown capacitors at the root of the problem. Replacing the caps is simple if you know how to solder very well & makes for an easy fix. Also, make sure you're pushing enough power through your supply.
Sep 18, 2017 | Dell OptiPlex GX280 PC Desktop
The computer dose not turn on.when i push the power button the cpu fan speed up and the speed of fan is going on.there is no video on the monitor.
This is a response I gave to someone else with a similar issue.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement - gx280 minitower) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google this and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Dec 24, 2010 | Dell OptiPlex GX280 PC Desktop
Help w/ my cpu it shut down automatically pls help
Check your power settings in the control panel, check that the keyboard has no buttons that can cause shutdown.
Check that your fans are working, and then check the event logs to see what has been happening...
Oct 11, 2010 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 restarts suddenly? all files closed and . the restart could be after 2,3 minutes of power on. I don't know why its behaving like this?
Hi, sounds like a crash, do you get any report messages after reboot? Try starting in safe mode; press Del button during initial bootup, once in safe mode you can reset to a time before the problem started. Hope this helps, if not come back to me?
Jul 10, 2010 | Dell Computer Refurbished SYSTEM BOARD -...
Reinstalled windows xp sp2...wont let me log on...invalid password
start windows in safe mode by shutting down the computer...then start the computer up and quickly tap on the F8 key...select safe mode....this will get you past the login where you can go into the control panel and go to "Users" and then change the password for your user ID
Apr 08, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Sep 30, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
216 people viewed this question
Alun Cox
