Question about Cobra 150 GTL DX Base CB Radio
About a cobra 150 gtl dx
Hi i just bought a cobra 150 gtl dx from a buddy he only used it once or twice and then bought a magnum s9 anyway i hear these radios had some issues what all do need to have done to it to make it work good and i would also like to upgrade iy if possible so i can get it to really reach out . thanks . shorty
  • 37 Answers
SOURCE: Night watch lights are dimmer than when new
The dimmer pcb driver has a tendency to go bad in these radios contact cobra and ask them they migth be able to send you one if not write back to ma and Il see if I can get you one...Chia
Posted on Jan 10, 2008
One Wire
  • 126 Answers
SOURCE: talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at rollincbmods@yahoo.com. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Posted on Feb 14, 2008
SOURCE: cobra 150 gtl dx nightwatch
You can send it into a factory authorized repair center, one is in TN that is highly recommended. This is an excellent radio if it has been adjusted properly and the factory mods have been done. Take a look at cbtricks.com for full info on the problems with these radios. Do not take to a regular repair shop; this is a SMT design(surface mount technology) and requires thousands of dollars of equipment and expertise to work on. Trust me I tried to adjust mine and messed it up and had to wait to have them reset it. This radio is very difficult to work on and should be sent into a factory rep. Contact cobra for repair station.
Posted on Aug 10, 2008
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
  • 773 Answers
SOURCE: just bought a cobra 148 gtl dx cant get a antenna
There really is no good indoor antenna.
You need to understand how the radio works and what reflections is.
Your radio radiates RF energy from the antenna. If the antenna is not the correct length for the frequency you are transmitting on then the signal will be reflected back into the radio and burn up the final transistor which is the lifeblood of the radio. This is your SWR or standing wave ratio.
The antenna has adjustments to correct this, and it is a simple process.
Here is what will cause you trouble. When you measure SWR in a car, you do it in an open lot, and not in a closed in area, because structures such as trees and buildings can cause reflection as well. If you inside a garage, then you will get a lot of reflection.
Beings you will be inside with the antenna, you are trapping the RF in a room, and it is reflecting most of the RF. Your SWR's will be really high, and hurt the radio.
Indoor antenna's are made so that it compensates for this, but your signal will be very weak, and your receive will be garbage.
Here is something you can do to get the antenna outside.
First get a real base antenna, like an antron 99, its good for the money.
Get 2 lengths of galvanized pipe 2" by 10 foot and a 1/4 inch thick steal plate. weld the pipe to the plate so that it will stand off it. Make sure its all the way off to side. connect the 2 pipes together, put the antenna on the end of it, and stand it up. Park the wheel of a car or truck on the plate. This will stabilize the pole.
Now you have a temp antenna tower you can take down and put back up easy.
I wouldn't go higher then 20 feet.
Posted on May 03, 2009
Can you still get the 150 GTL DX or has it been replaced with the 29NW?
Cobra 150 &200 were amateur radios. and are no longer made.
so thats totally different than a 29.
Jul 01, 2014 | Cobra 150 GTL DX Base CB Radio
Cobra 150 gtl dx peak and tune
first off if you don't have the proper equipment to do this you will have a cobra 150gtl dx used in the box that you can use for a chock block. turn the wrong can and you will never be able to get it back to working order.
Jan 16, 2012 | Cobra 150 GTL DX Base CB Radio
Hi. I have a cobra 150 gtl dx and the needle does not move and it seems nobody listens to me when transmitting. What might be the fault?
These have a known problem with the radio's finals. They may be bad and this would require replacing by a technician.
Feb 12, 2010 | Cobra 150 GTL DX Base CB Radio
Need a new Cobra 150 GTL DX power,vol,sqlch pot
you can write to parts department requesting price if you have a truck stop around you which has a cb shop they can sell u one
Jun 26, 2009 | Cobra 150 GTL DX Base CB Radio
Getting regular cb chanels
go to cbtrick.com to radio information go to corba radios and you will find the mod for 11 meters.
Jan 01, 2009 | Cobra 150 GTL DX Base CB Radio
Cobra gtl dx 150
audio is clipping due to improper setting amount of modulation. should be set at 95% retune it ...docs cb shop ny
May 04, 2008 | Cobra 150 GTL DX Base CB Radio
Dec 15, 2007 | Cobra 150 GTL DX Base CB Radio
Cobra 150 GTL DX Base CB Radio Logo
173 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
