Question about GE Dishwashers
GE Profile Dishwasher PDW7300 Died on me!
My GE Profile Dishwasher PDW7300J10BB Just stopped mid-cycle the other night. Now it doesn't light up, start, beep or anything. I've already reset the breaker in the basement to no avail. What next? Is there an internal fuse or switch I can reset? Please help. Thanks! :-)
Thanks for the pointer on the arcing. Funny thing is .. I did the electrical myself and I always make sure things are tight and connected properly. Was a little shocked to see the melted wires and caps. I soldered them this time .. if it happens again it was not arcing. Im going to check with GE and see if there was a recall or not. The wires to the washer seem a little too high gauge to me.
Posted on Jul 22, 2012
Turns out the folks who installed it did a shoddy job of connecting the power. The power connections were not twisted on tightly enough, and after time, the continuous arcs of current between the loose connections burned through the wire nuts and finally separated the poorly twisted electrical wires. SOLUTION: Turned off power to the dishwasher, chopped off old, burned up wire ends, stripped some insulation off, twisted/spliced the electrical wires back toghether TIGHTLY and then tightly closed it all with quality wire-nuts. Power came right back on! :-) Yay! The only problem is, since the washer had been sitting/dead for a week or two, the lubricating water on the motor's ceramic bearing dried up, causing the motor to seize up. Had to replace the motor. :-( But everything is working fine now!
Posted on Apr 18, 2009
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
Aug 02, 2017 | GE 24 in. Profile PDW9800J Built-in...
Stops in mid cycle can advance timer and will start running again
unplug the machine over night and try again. check to make sure there are no wires lying on top of the IC's on the control boardl. could also be a bad control board (timer)
May 25, 2010 | GE Profile Prodigy WPSE4200A
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
PDW7300 Dishwasher leaves clumps of soap in the dispenser after wash cycle
have you tried a different brad dish soap?  Is the water getting hot enough?  Is the water valve opened completely?
Mar 15, 2009 | GE PDW7300N Dishwasher
GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Feb 20, 2009 | Dishwashers
Ge pdw7300 leaking water
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
kuyeyu
Dec 30, 2008 | GE 25 in. PDW7300J Built-in Dishwasher
Dishwashers Logo
796 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
