Question about Stanton STR8-50 Turntable
Fuse i mixing the other day and one of my decks just cut out with the power,i think it may be the fuse although im not entirely sure
  • 515 Answers
The fuse is located on the rear of the unit. Remove it and take it to an electronics shop for replacement. If it does not work, then you've fried the transformer and will need to have it replaced by a qualified technician.
Posted on Sep 23, 2007
What amp fuse should I use for my 1991 Alfa Romeo? Which fuse compartment do I find it at? (Firewall, under steering wheel or passenger compartment)
Although not entirely sure, I suspect the fuse is under steering wheel, and should be labelled. Normally 15 or 20 amp I think. If you can't tell which, pull each fuse one at a time until you find a bad one. It is always possible the wiper motor is bad, but rarely happens.
Dec 19, 2014 | Alfa Cars & Trucks
I have a John Deere garden tractor 420 I was mowing the engine stopped I check the 25 amp fuse it was blown. I replaced it turned the key there is absolutely no power
Im gonna first assume that the 420 you have is the 1986 model and not the 68 model , second this model has hydraulic lift on mower , this model has a electric clutch on pto , I assume that you dissengauged the deck drive before trying to restart , but now if you forgot to do so before replacing fuse it would go again if it's what i think it is , so first disengauge deck second ck fuse again replace if nessacary , start engine attempt to engauge deck if engine dies or it does a short time later, ck your wiring to your pto clutch Look for what looks like a chewed up wire finding none replace pto clutch magnet (or entire clutch if lots of hours on it) also ck out my youtube video on finding electrical faults on lawn tractors this might help ya .
Jun 05, 2014 | Garden
Blowing fuses when power is applied on my Toshiba VHS M-754
you might have to change the entire power cord as well as the plug
Apr 13, 2014 | Toshiba Six Head Vcr Deck M-752 W/ Remote...
I'm trying to install a pioneer deh-1100 into a 2002 chevy impala... have all wires connected, amp is on, but deck will not cut on
On pioneers, i know that some of them, you have to twist the yellow AND red wires together on the power from your car. Make sure you are grounded. Radio fuse isnt blown, or any fuse on the back of the deck.
Apr 23, 2011 | 2002 Chevrolet Impala
Everytime I cut it on. It cuts back off like there is something wrong with it
If you turn it on and it clicks right back off you may have a short. Make sure the wire panel does not have any straggler wires going from one connector to another. Also you may have a very weak fuse. Check the fuses in your amp and at the battery terminal. Make sure the power, ground and remote wires are solidly connected. Make sure that ground is tight. Is the deck shutting off at the same time your amplifier does? The remote wire off the deck powers that amp so if the deck is also cutting out the problem may be the deck and not the amp. If this is the case then run through the steps I listed above but with the deck as well.
Regards, Tony
Mar 24, 2011 | Sony XMGTX1852 Car Amp
Where is the Fuse??
once you take off the back of the tv you can see where the power cord plugs in and there is a thin metal cover you pull that off and unplug the power cord from the board and right in front of that under the other metal cover you will see a small fuse with a white middle. pull it uot and get a new one. i think that is what you are looking for
Aug 19, 2008 | Protron PLTV-32 Television
My subwoofers cut out
You are most likey running too much power from the amp to the speakers.. you might want to try just notching the bass down a notch or 2.. just enough that the bass will hit
Nov 16, 2007 | Car Audio & Video
Moodey newmark cd mix 2
Just wanted to tell you i have the same problem with my right deck! after about 2-3 hours of usage the right deck will start to skip while playing a cd...almost sounds like im fast forwarding then itll just stop playing, but only on the right deck! Ive noticed that it happens when the unit gets hot whether by usage or sunlight. Now as for youre issue about the crackling, i have two staements one is the cd youre playing scratched? ive had cds that have had minor path scratches that follow around the cd not straight across scratches..while playing this sounds like static or crackle then fades away! I would recommend playing the cd in a entirely different unit to see if this is the prob...if you know this is not the issue i would say that its a loose connection to a capicator or that a capacitor is on the way out...this happens when the capacitor is cold and doesnt let proper flow to go thru but as the capacitor heats up it it may heat the connection making a better contact.....just out of curiousity do you have the right rated fuse in the holder.. sometimes just having a fuse off by a couple of volts or milliamps can cause the same effect
Nov 12, 2007 | Nu Mark Numark CD-Mix-2 Dual CD...
No power to the cd receiver.
There is a fuse both in the back of the deck...and in your fuse panel... Refer to your service manual for the car to find the correct fuse for the audion system. and Refer to your service manual for your deck to see what im talking about...all the fuses Ive seen just plug into the back of the deck.
Mar 29, 2007 | Kenwood KDC-V7017 CD Player
Stanton STR8-50 Turntable Logo
251 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
