Question about Xerox 8830 Copier
Paper jam warning icon flashes but there is no paper jam.
XC865 has paper jam warning, but there is no paper jam. Won't reset. Just flashes the jam icon.
  • 4 more comments
  • reinikeart Apr 18, 2009
    It had been a sporadic problem. Paper would start to feed then stop. It wasn't really jammed at all. But I would remove the started sheet and close the lid and all worked fine. This time there was no jam at all or feed of paper, just the shutdown and warning light.
    Any tips on where the sensors are?
    Inside is very clean, but blew air anywhere that looked like a sensor. Still getting jam warning.
    While searching for a sensor, I found a small spring had come loose from a little black lever in the middle of the feed roller just above the bottom paper tray. When I reattached the spring, it held the lever in an up position. Everything works fine now. Thanks for the help.
    I was looking for an optical sensor, but found it was a mechanical problem with the lever.
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    1. Was there a jam, an you removed the paper, an it still indicates a jam?
    2. Or was there NEVER a jam, and the light is just lit-up?
  • 227 Answers
Well I would take a can of air and blow off the sensors, especially where you began to have problems. The sensors (over time) become coated with paper dust and now reflect back on themselves thinking there is paper there all them time. From your description of the problem, it seems like the issue-intermitten jams/intermitten false jams, until a total false jam.
Posted on Apr 18, 2009
  • 1 more comment
  • Arthur Hoffmann
    Arthur Hoffmann Apr 18, 2009
    look for 2 wires anywhere inside... probably a sensor on the other end
  • Arthur Hoffmann
    THERE is your problem.... That spring and lever are part or a sensor. if you can find it, replace it if it is not broken.
  • Arthur Hoffmann
    Arthur Hoffmann Apr 19, 2009
    Well it is a photo interupt sensor, the arm breaks the plane of the led when NO paper is present,
We have XC865 the copier was working just fine until today. The paper keeps jamming inside. It would start to copy and then just gets stuck in the middle of the cycle. So I have to open the machine up...
Most likely a common problem of a broken fuser drive gear. This is especially true if the lead edge of the paper is stopping at the fuser assembly. This is the assembly that is hot to the touch. There is a upper fuser roller drive gear that breaks on these and causes the fuser roller to stop turning. So everytime the paper gets to the rollers it stops and a jam reults. The gear is 16.00 at precisionroller.com part number M510X
Here is a picture of the gear.
Sep 17, 2010 | Xerox Office Equipment & Supplies
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
The orange warning light flashing what can i do to stop it?
check for paper jam if any or p head or cartridge indication for replacement
some symbol my blinking in display for user attention
this also indicate for error in plotter check for display icon and if you find any special icon other than normal screen as earlier, it will give information like paper with X mark ( no paper in tray )or paper jam ( two circle with Z mark )
or may be some screw driver and spanner X mark that can decode to give reason for LED blinking
if you get tool X mark check for ink level box in each row to check error code, its would be 6 numbers of rows and each row may some box
need to check and confirm to verify the error code
Nov 06, 2009 | HP Designjet 110plus nr InkJet Printer
Paper jam stays on without paper jammed in machine
try this... reset the printer...
Next... reboot the computer... this should reset the printer and the computer and the system...
Oct 25, 2009 | Lexmark X4550 InkJet Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Copier won;t work
the sensors are little plastic peices that hang down along the paper trail its how the printer determines where the paper is. There would be one along the trays.
Feb 12, 2009 | Office Equipment & Supplies
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
986 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
