Question about Hotpoint WMA30 Front Load Washer
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.it does drain out the water tho.
    Sergeant:
  • 399 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 13, 2009
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
GW 612 Fiaher Paykel wont complete drain or spin cycle
Do you get any errors on the display lights?
Dec 03, 2012 | Washing Machines
My washer will not complete a full cycle.. when on rinse does not finish beeps as though it done but is still on rinse..also fabric softner does not drain into machine. machine will spin if I manually set...
my washer does not finish a full cycle ;but is still on rinse and its a bosch and i was wondering
were is the fuses kept in the machine,
sandra read
sandrarread@yahoo .co uk
Jan 22, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Water is not draining and rinse light is flashing
top load fish pak washer wont dump or spin.constant beeps. rinse spin light and center wash light on .could dump valve be bad or how could line get clogged for dump
Nov 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint WMA30 Front Load Washer Logo
368 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
