Question about Amana ARSE66MB Side by Side Refrigerator
My refrigerator is freezing everyting
Amana - side by side model # scd25n2w.
Adjusting the temp knob is ineffective.
  • 153 Answers
Ur temprature knob is not adjusted so u have to read the manual ok.read it and adjust it
Posted on Jul 21, 2009
The bottom crisper drawer area freezes and anything along the back of the fridge. I have taken the drawer out to help increase air flow that doesn't work. I have also tried adjusting the temperature i
is the fridge going into defrost mode or is freezer building up with ice? may also want to check the cold control thermostat knob and the defrost timer and also check door seals
Feb 14, 2015 | Amana Refrigerators
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
    seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
    Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
    I have an Amana side by side refrigerator, model SXD22S2E. The ice maker does not work. It freezes Ice but it does not dump the ice into the ice bucket. -- Suggestions?
    Check temp of freezer (10 degrees or better)
    If it is then you probably need a new icemaker.
    If this was helpful please rate me.
    Leo Ponder Appliance-Tyler,Texas
    imufo2@sbcglobal.net
    Aug 08, 2010 | Amana Refrigerators
    Water reservoir in bottom back of frig keeps freezing up.
    Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
    Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Ouramana model AF12538AEB4 freezes items on left side
    Those are notorious for that because the icemaker is in the refridge compaertment which is freezing inside of it. Try to adjust your temp settings so the items will not freeze. Sometimes you will have to set your temp setting around 45 or so. Another good idea is to put a thermometer in the fridge so you know exactly wht is going on in there.
    Sep 13, 2009 | Refrigerators
    Amana side by side red turn knob at the bottom what is it?
    thats the defrost timer. its merely a clock thatcycles the refrig in and out ofdefrost cycles,shouldnt be set to any particular place, it will free turn just a s as clock will
    Feb 03, 2009 | Amana 23.1 cu. ft. Side-by-Side...
    Amana side by side does not freeze nor does it get cold
    first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
    let me know
    Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
    Amana Refer. runs all the time.
    Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
    The unit gets low on refrigerant and just dosen't cool properly.
    May 17, 2008 | Amana Refrigerators
    Amana ARSE66MB Side by Side Refrigerator Logo
    171 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
