I cannot connect to the internet on my laptop - get message adapter radio turned off
I cannot connect wireless to the internet on my laptop-get message adapter radio turned off
  • Barry Parks May 11, 2010
    What is the make and model of the laptop?
  • 393 Answers
Look for a little radio symbol on your keys numbered f1,f2,f3,f4,f5 usually in a different colour.
eg. if it is on f2 hold down the key marked Fn or Func and then press f2 and it should turn on
press again to turn it off again.
without the exact model of laptop its hard to tell exactly
Posted on Jul 07, 2009
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
Cannot connect to the internet. Error message says adapter not connected. Where is the adapter?
For most laptop/notebook/netbook computers, the wireless adapter is "inside" the casing.
By "not connected", it means that your wireless-adapter *IS* physically connected to your computer, but it does *NOT* have a "logical" connection to the wireless-adapter inside the router.
Click Start
Click Control Panel
Click Network Connections
Click View Available Wireless Networks
Select the SSID corresponding to your router.
Click Connect.
Supply an ID/password/pass-phrase, to get "connected".
Dec 14, 2009 | HP Computers & Internet
How do I turn on my wireless capability Gateway MD2614u
There is no hard switch for the wifi radio in your laptop model. Look at the Function Keys and tap the key that enables wifi radio
Jul 30, 2009 | HP (319468-002) (319468002) 802.11b...
802.11g Network Adapter Radio Control Switch
Try FN+F2 to toggle the wireless radio on / off. Also check to make sure that driver has the radio enabled. (right click on the network adpter select properties. Click on the advanced tab. verify that radio on/off is set to on.
Feb 19, 2009 | Computers & Internet
My network says that it can't find the internal wireless adapter
You may have to reboot your PC and try to connect again.
If you have "Viewed all available networks" and tried to connect to your Wireless network but cannot what kind of error message are you getting ?
To quickly find out if you have Internet Connectivity coming in at all from your Internet Service Provider turn off your wireless switch on your laptop and try to connect a cat5 directly from your PC ( connect cat5 cable to what looks like a slightly larger telephone jack on the side or back of your laptop) to the back of your router and see if you browse the internet. You may have to reset your router (unplug and plug)
Jan 10, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Lap top problem
Wireless network adapters require an associated wireless receiver (such as a wireless router or wireless access point) to recieve the radio signals from the adapter and eventually route them to a wire and in you case it would be the wire providing internet services to your desktop computer. If there is no wireless receiver there is no device to convert the radio communications of the wireless adapter and rout those signals to the internet.
I hope this helps.
Dec 08, 2007 | Computers & Internet
It's not a physical switch, and they really should put more thought into the error messages they write. To "flip" the "switch" you hold down your function key and hit F2 (you'll notice a little symbol on the F2 button - that's the "radio switch"). After that, just right click on your wireless connection and choose repair.
Aug 29, 2007 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
