I selected 'Add Windows components' to configure faxing, The wizard went through the motions and reported success, but under Accessories/communications/fax the folder is empty. I used to have this facility running on this machine - maybe I've lost relevant .dll files ?
  • 2 more comments
  • gerryh907 Apr 17, 2009
    As I said the Fax folder is empty (under Accessories etc) but I still have the fax console on the desktop (from when it used to work) If I select 'configure fax' I get a message 'A connection to the fax server cannot be made' The console also reports (at the bottom that no fax printer is present). I have been into Control panel/printers & faxes/set up fax - a fax printer icon appears then disappears again.
  • gerryh907 Apr 18, 2009
    Downloaded Hotfix and opened it - message displayed that the updates on my machine were newer than in the package and therefore no need to install. So still no result. Maybe this problem started after installing SP3??
    Thanks for that - downloaded and ran it - unfortunately no result however.
  • gerryh907 Apr 19, 2009
    Sorry, no help from these links. From asking around I gather that the fax facility seems to have been omitted from SP3 and this has caused the problem. Anyway round this?
  • 854 Answers
Please click the link below...maybe this will help
http://support.microsoft.com/kb/884018
Posted on Apr 20, 2009
  • 527 Answers
Sir,
Check all these links to solve your problem and just go through the site........
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Apr 18, 2009
  • 315 Answers
To install the fax component, follow these steps:
  1. Click Start, and then click Run.
  2. Copy and paste or type the following command in the Open box, and then click OK: appwiz.cplIt may take several seconds for your computer to compile a list of programs. The Add or Remove Programs dialog box opens.
  3. Click Add/Remove Windows Components to the left of the list of programs to start the Windows Components Wizard. This takes several seconds.
  4. In the Components list, click to select the Fax Services check box, and then click Next. Setup installs the fax services.
  5. If you are prompted, insert the Windows XP CD, and then click OK.
    If the Welcome to Microsoft Windows XP window opens, click the X in the upper-right corner to close it.
  6. Click Finish, and then click the X in the upper-right corner of the Add or Remove Programs dialog box to close it.
The fax component of Windows XP should be installed now. If you have problems installing the fax component, go to the "Next Steps" section.
The next step is to configure the fax service. To do this, go to the "Configure the fax service" section. Configure the fax service loadTOCNode(2, 'moreinformation'); To configure faxing capability in Windows XP, follow these steps: Step 1: Configure the cover page, select a modem, and enable the fax service to send and receive faxes loadTOCNode(3, 'moreinformation');
  1. Click Start, point to All Programs, point to Accessories, point to Communications, point to Fax, and then click Fax Console.
    The Fax Configuration Wizard starts.
  2. If you are prompted, type the area code or city code of your present location, a carrier code, the number that you must dial first to dial out, and the telephone system that you are using (Tone or Pulse), and then click OK.
    If the Phone and Modem Options dialog box is displayed, select your location (if more than one exists), and then click OK.
  3. Click Next, type the information that you want to appear on your fax cover page, and then click Next.
  4. In the Please select the fax device list, click the modem that you want to use.
  5. If you want to disable the ability to send faxes from this computer, click to clear the Enable Send check box.
    Note By default, the Enable Send check box is selected.
  6. Click to select the Enable Receive check box if you want the computer to receive faxes.
    Note When this check box is selected, you can click Manual answer if you do not want the computer to automatically receive faxes. By default, automatic answering is enabled.
  7. Click Next.
Step 2: Enter TSID and CSID information and configure printing and storing preferences loadTOCNode(3, 'moreinformation');
  1. Type the Transmitting Subscriber Identification (TSID) that you want to use in the TSID box.
    Note The TSID is mandatory in some areas. This identification information typically appears in the header area of a fax that you receive and can help you recognize the fax machine where the fax originated. The TSID typically includes the sender's fax number and business name.
  2. Click Next.
  3. Type the Called Subscriber Identification (CSID) that you want in the CSID box.
    Note The CSID text that you enter appears on fax machines that send faxes to you. For example, if you enter "123 Fax", a machine that sends you a fax might display the message "Sending a fax to 123 Fax" while sending.
  4. Click Next.
  5. Click to select the Print it on check box if you want each fax that you receive to be automatically printed. When you select this check box, you can select a specific printer to print the fax.
  6. Click to select the Store a copy in a folder check box if you want to archive a copy of each fax. When you select this check box, you can specify the storage location for the fax copy.
  7. Click Next.
  8. Confirm the configuration settings in the Configuration Summary list, and then click Finish.
    The Fax Configuration Wizard closes and the Fax Console window opens. The computer is now configured to send or receive faxes.
If you have to change your fax service settings, use the Fax Configuration Wizard by following the instructions in the "Change the fax configuration" section.
If the Windows fax service is not working as you expected, go to the "Next Steps" section. For information about receiving faxes or sending a scanned document or image, go to the "More Information" section. Change the fax configuration loadTOCNode(2, 'moreinformation'); Use the Fax Configuration Wizard to change your fax service settings. You can start the Fax Configuration Wizard from the Fax Console window. To start the Fax Configuration Wizard, follow these steps:
  2. In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration Wizard.
    Note You may be prompted to "unblock" the program. If this is the case, click Unblock.
Posted on Apr 17, 2009
Fax driver missing
Microsoft Office 2010 has a feature that lets you send Outlook, Word, Excel, and PowerPoint files as Internet faxes. This feature relies on having the Windows Fax Printer Driver or Fax Services installed on the computer to send the faxes. The Windows Fax feature is not enabled by default for all editions of Windows. If your edition of Windows includes the driver or service, you must install it before you can send Internet faxes.
Which operating system are you using? Windows 7
  1. In Control Panel, click Programs, and then click Programs and Features.
Note In Classic view, double-click Programs and Features.
  1. Click Turn Windows features on or off.
  2. In the Windows Features dialog box, under Print and Document Services, select the Windows Fax and Scan check box.
  3. Click OK.
za010077668.gif Top of Page
Windows Vista The Windows Fax Printer Driver is included in the following editions of Windows Vista: Business, Enterprise, and Ultimate.
  2. In the Windows Features dialog box, select the Windows Fax and Scan check box.
  3. Click OK.
Windows XP
  1. In Control Panel, click Add or Remove Programs, and then click Add/Remove Windows Component.
Note In Classic view, double-click Add or Remove Programs.
  1. In the Windows Component Wizard, select the Fax Services check box.
  2. Click Next.
Windows Server 2008 To create a fax server, you must install the Fax Server role. This installs the Fax Server role page, Fax Service Manager, Windows Fax and Scan (with faxing capabilities only), the Fax service, and the Fax printer.
  1. In Control Panel, under Programs, click Turn Windows features on or off.
  2. Right-click Roles, and then click Add Roles.
  3. In the Add Roles Wizard, under Select Server Roles, click Fax Server role.
Note If Print Services are not installed, you are prompted to install it.
  1. Click the users or groups that you want to send faxes.
  2. Click who you want to have access to the fax server inbox.
  3. Click Install.
Windows Server 2003 The Fax Service is included in all editions of Windows Server 2003 except the Web edition.
  1. In Control Panel, click Add/Remove Programs.
  2. In the Add/Remove Programs dialog box, click Add or Remove Windows Components.
  3. In the Windows Component Wizard, select the Fax Services check box, and then click Next.
  4. If you want to share the fax printer so that everybody in the network can send and receive faxes, click Yes.
  5. Click Finish.
Click here for fax driver
Jul 26, 2011 | Office Equipment & Supplies
Tip
Windows XP fax
If you need your<b> PC</b> to be able to fax, you must install the <b>Windows XP fax</b>. Add / <b>Remove Programs</b>, click Add / Remove <b>Windows Components</b>. In the <b>Windows Components Wizard</b>, select the check box next to <b>Fax Services</b> and make sure you have the installation CD handy.
on Feb 24, 2011 | Computers & Internet
Tip
Can I send and receive faxes from my computer ?
Yes. You can. You will need a telephone line, a modem and a scanner, along with your computer. And before you can send and receive faxes from your computer, you will need to install the fax component. This fax component is not installed in Windows XP by default.
How to install the Fax Component:
Go to Start Button -> Control Panel -> Add/Remove programs ->Click on Add/Remove Windows Components ->Click in the Fax Services check box and click Next. Now you will see a Windows Component Wizard, which will setup the Fax service in your computer. Make sure the modem and telephone line are connected to your computer, along with the Scanner.
Now you have to configure the Fax component in your computer. In order to do that, you have to go to the Fax Console which is located at
Start Button ->All Programs->Accessories->Communications->Fax ->Fax Console
fax_xp.gif In the Fax console, click on the Tools Menu and select Configure Fax - this will start the Fax configuration wizard. Click Next to start configuring the fax service in your computer.
Enter your Name, Your Company's name and your fax (Telephone) number on the Sender Information page.
Your modem will be selected under Select Device for Sending or Receiving Faxes - if you have more than one modem, you will have to select the correct device to send and receive faxes in your computer. You will also have to specify if the send and receive options - whether you will manually answer incoming faxes or if you want your computer to automatically answer them for you.
Remember to Enter your Company's Name and Fax Number under Transmitting Subscriber Identification(TSID) and Caller Subscriber Identification (CSID). These fields are very important.
Now, under Routing Options, you will need to specify where incoming faxes are going to be stored in your computer. You can specify a local folder or just let it go to the default location, which is the Fax Console.
You can change these settings anytime you want by running the Fax Configuration Wizard again from Tools -> Configure Fax.
Sending Faxes from Your Computer
You can fax any document that is stored in your computer. You can also scan a document and fax it by sending it to the Fax Printer in your computer.
To fax a document from your computer, Click on the File Menu of the document and select Print. Then under print (or Print Setup), select Fax in the Printer Name box. This will open the Send Fax Wizard. You can also use the option called Send To and select Fax Recepient if you are using MS Office.
As soon as you hear your computer dialing, the Fax Monitor (as shown in the image below) will start up
fax_monitor_xp.gif How to Fax Scanned documents:
Another way to send a fax from your computer is to scan documents and then fax it through your Fax Printer. This can be made possible by using your scanner software. You can also fax from a scanner using the tools provided by Windows XP.
For this, go to the Control Panel and click on Printers and Other Hardware, then select Scanners and Cameras and then, double-click on the icon for your scanner to start the Scanner and Camera Wizard.
Then, on the Choose Scanning Preferences page, click Grayscale Picture and then click Preview to start the scanner.
Provide a name and location for the scanned document.
Now, go to the saved image which you scanned just now and right-click on it and select print - This will start the Photo Printing Wizard.
Click on the check box for the image to be faxed and select Fax as the printer you want to use.
When you finish the Photo Printing Wizard, the Send Fax Wizard opens and you proceed as described in the procedure for sending a fax from your computer.
Faxing from MS Outlook:
You can also fax from MS Outlook by adding the Fax Transport Service as an email account.
Receiving faxes on your computer.
Remember, you have already specified where the incoming faxes should be located and also how you wanted the incoming fax calls to be answered -manually or automatically. The Fax Monitor opens up automatically when the modem detects an incoming fax.
To view an incoming fax, go to the Fax Console and click on Inbox. Double-click on the fax entry you have just received and it will open up in the Windows Picture and Fax Viewer. Fax files are images in TIFF format so they cannot be edited. But u can print it out or email it to anybody else as an attachment.
on Jul 06, 2010 | Computers & Internet
How to set DNS setting
This step-by-step article describes how to install and configure DNS on your Windows Server 2003 computer.
Before You Start loadTOCNode(2, 'summary'); Before you start to configure your DNS, you must gather some basic information. Internic must approve some of this information for use on the Internet, but if you are configuring this server for internal use only, you can decide what names and IP addresses to use.
You must have the following information:
  • Your domain name (approved by Internic).
  • The IP address and host name of each server that you want to provide name resolution for.
Note: The servers may be your mail servers, public access servers, FTP servers, WWW servers, and others.
Before you configure your computer as a DNS, verify that the following conditions are true:
  • Your operating system is configured correctly. In the Windows Server 2003 family, the DNS service depends on the correct configuration of the operating system and its services, such as TCP/IP. If you have a new installation of a Windows Server 2003 operating system, then you can use the default service settings. You do not have to take additional action.
  • You have allocated all the available disk space.
  • All the existing disk volumes use the NTFS file system. FAT32 volumes are not secure, and they do not support file and folder compression, disk quotas, file encryption, or individual file permissions
Install DNS loadTOCNode(2, 'summary');
  1. Open Windows Components Wizard. To do so, use the following steps:
    1. Click Start, click Control Panel, and then click Add or Remove Programs.
    2. Click Add/Remove Windows Components.
  2. In Components, select the Networking Services check box, and then click Details.
  3. InSubcomponents of Networking Services, select the Domain Name System (DNS) check box, click OK, and then click Next.
  4. If you are prompted, in Copy files from, type the full path of the distribution files, and then click OK.
Configure DNS loadTOCNode(2, 'summary');
  1. Start the Configure Your Server Wizard. To do so, click Start, point to All Programs, point to Administrative Tools, and then click Configure Your Server Wizard.
  2. On the Server Role page, click DNS server, and then click Next.
  3. On the Summary of Selections page, view and confirm the options that you have selected. The following items should appear on this page:
    • Install DNS
    • Run the Configure a DNS Wizard to configure DNS
    If the Summary of Selections page lists these two items, click Next. If the Summary of Selections page does not list these two items, click Back to return to the Server Role page, click DNS, and then click Next.
  4. When the Configure Your Server Wizard installs the DNS service, it first determines whether the IP address for this server is static or is configured automatically. If your server is currently configured to obtain its IP address automatically, the Configuring Components page of the Windows Components Wizard prompts you to configure this server with a static IP address. To do so:
    1. In the Local Area Connection Properties dialog box, click Internet Protocol (TCP/IP), and then click Properties.
    2. In the Internet Protocols (TCP/IP) Properties dialog box, click Use the following IP address, and then type the static IP address, subnet mask, and default gateway for this server.
    3. In Preferred DNS, type the IP address of this server.
    4. In Alternate DNS, type the IP address of another internal DNS server, or leave this box blank.
    5. When you finish setting up the static addresses for your DNS, click OK, and then click Close.
  5. After you click Close, the Configure a DNS Server Wizard starts. In the wizard, follow these steps:
    1. On the Select Configuration Action page, select the Create a forward lookup zone check box, and then click Next.
    2. To specify that this DNS hosts a DNS zone that contains DNS resource records for your network resources, on the Primary Server Location page, click This server maintains the zone, and then click Next.
    3. On the Zone Name page, in Zone name, specify the name of the DNS zone for your network, and then click Next. The name of the zone is the same as the name of the DNS domain for your small organization or branch office.
    4. On the Dynamic Update page, click Allow both nonsecure and secure dynamic updates, and then click Next. This makes sure that the DNS resource records for the resources in your network update automatically.
    5. On the Forwarders page, click Yes, it should forward queries to DNS servers with the following IP addresses, and then click Next. When you select this configuration, you forward all DNS queries for DNS names outside your network to a DNS at either your ISP or central office. Type one or more IP addresses that either your ISP or central office DNS servers use.
    6. On the Completing the Configure a DNS Wizard page of the Configure a DNS Wizard, you can click Back to change any of the settings. To apply your selections, click Finish.
After you finish the Configure a DNS Wizard, the Configure Your Server Wizard displays the This Server is Now a DNS Server page. To review all the changes that you made to your server in the Configure Your Server Wizard or to make sure that a new role was installed successfully, click Configure Your Server log. The Configure Your Server Wizard log is located at %systemroot%\Debug\Configure Your Server.log. To close the Configure Your Server Wizard, click Finish.
-----------please let me know if this guideline helps-------------
Jun 20, 2011 | Computers & Internet
Need to fax docs w/ a Dell 942 all-in-one print-fax-copy-scan.
To install and configure the Microsoft® Fax software:Click the Start button.
Click the Control Panel icon.
Double-click the Add or Remove Programs icon.
Click the Add/Remove Windows Components icon on the left side of the Add or Remove Programs window.
When the Windows Components Wizard window appears, click to place a check in the box next to the Fax Services listing.
Click the Next button.
When the Files Needed window appears, insert the Windows® XP CD into the CD-ROM drive.
From the Copy files from: drop-down button, select the drive-letter that represents your CD-ROM drive.
Click the OK button. to automatically open and close several installation windows.
When the Installation Complete window appears, click the Finish button.
Close the Add or Remove Programs window.
Click the Start button, point to All Programs, point to Accessories, point to Communications, and then point to Fax.
Click Fax Console.
When the Welcome to Fax Configuration window appears, click the Next button.
Enter any appropriate information in the fields provided.
Select your data/fax modem from the drop-down button located below the Please select the fax device listing.
Click the Manual answer button or Automatically answer after (specify number of rings) button.
Click to select the Enable Receive listing.
 Note:
  By selecting the Enable Receive check box, you can receive faxes. However, selecting this option may cause the computer modem to answer all incoming phone calls in which you may not receive voice mail.
Enter your TSID (Transmitting Subscriber Identification) information in the field provided.
Enter the CSID (Called Subscriber Identification) information in the field provided.
When the Routing Options screen appears, click to select the Print it on check box if you want each received fax to be automatically printed. If selected, use the drop-down menu to the right of this field to select the Dell AIO Printer to print the received fax. Your printer must be on and connected to your computer in order to automatically print faxes.
To create an archive copy of each fax, click to select the Store a copy in a folder check box.
Click the Browse button to select the desired archive location.
Click the Next button to display the Configuration Summary list.
Confirm your configuration settings are correct, and then click the Finish button.
You are now ready to send or receive faxes.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&dn=1091795
Nov 14, 2009 | Office Equipment & Supplies
Tip
How to add or remove Windows XP components
Windows XP can be customized to a certain degree by adding or removing components. Some components (such as Fax Services) can add functionality that users may or may not want, while other components (like Accessories and Utilities) are used by almost everyone.
If there are components you don't use -- for example, MSN Explorer or Windows Messenger -- you can disable those components to save a little bit of disk space. The components won't be deleted from your computer, however, so if you decide you want to re-enable them later, you can easily do that.
To add or remove Windows XP components, open the Control Panel and double click Add or Remove Programs. Along the left side of the window is a button that says Add/Remove Windows Components; click that button.
The Windows Components Wizard will appear. Scroll through the list of components and decide which ones you want to enable or disable. (The ones you currently have enabled have a check mark next to them.) Checking a component will enable it, while removing the check mark will disable it.
Some components have multiple parts to them. Highlight these components and click the Details button to see which applications or services make up that component. You can choose to only enable or disable certain aspects of each component, rather than the component as a whole.
When you have made the changes that you wanted to make, click the Next button at the bottom of the screen. The Wizard will configure your new components (or uninstall the ones you don't want), and when it finishes you'll see a message saying that the process has been completed. Click Finish to close the Wizard.
on Jun 16, 2010 | Microsoft Windows XP Home Edition
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
Need to setup windows xp faxing
Since you donot have the windows xp cd , you would not be able to enable the fax feature in windows xp home edition.
Alternatively you can download a fax program from the interent and configure the same to send faxes.
One such porgram is called snappy fax, can be downloaded from the link below
http://www.snappysoftware.com/
Thanks
Proton
Jan 31, 2009 | Microsoft Windows XP Home Edition
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
