Home | Magic Chef | CYE4000AWW Electric Dryer | My dryer will start and...
Magic Chef CYE4000AWW Electric Dryer
Problem for Magic Chef CYE4000AWW Electric Dryer
My dryer will start and then stop when it gets hot
By scott651 on Apr 17, 2009
I can start drying my clothes and after a while it stops. I can lt it cool down and then dry some more.
Comments:
Apr 20, 2009
- I tried all this but I did not check to see it the motor would wiggle. AfterI cleaned it and checked for bearing being worn out I tried it again with same results, it would run a litlle and stop again. It is about 5 years old
Solution #1
posted on Apr 17, 2009
Not Rated)
Healeyman
Rank: Wiz
Rating: 82%, 220 votes
Lint build up in the duct will do that. If that's clear, it could be a problem around the fan area. You have to take the machine apart to check that. While apart, vacuum everything, including all the crooks and crannies of the motor. Your motor could be worn out if the machine is real old, ten years or more. Wiggle the motor at both ends, it should spin smoothly, not move up and down at all.
Comments:
Apr 21, 2009
- A motor will stop if it overheats, there's a sensor in the motor to protect it. Some dryers have a center bearing that wears out. There are heat sensors all over the place that can stop the machine if that area overheats, they are mighty hard to diagnose, because by the time you get to them, they are cool again. Low voltage, which can be caused by loose wiring anywhere from the breaker all the way through to the white wire connection at the breaker box, will cause a motor to stop. You are going to have to attack this problem scientifically. Measure the voltage while the machine is running, it must not change. Does the motor stop, or does the heat just turn off? Look at the schematic, you'll see the circuit for the motor. It includes the door switch, the timer, all the sensors, and the start button. After starting, the start button should be out of play, but check to make sure the run circuit does not go thru it too. Run the machine 'air only', see how the motor runs alone.
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CYE4000AWW Electric
Questions and Unsolved Problems for Magic Chef CYE4000AWW Electric
Do you recommend Magic Chef CYE4000AWW Electric Dryer?
Answer
Answer
My dryer stopped working during a cycle last night and won't start again. The light is no longer... (More)
Answer
How do I replace the fuse in a Magic Chef microwave that is part of the oven.
Answer
Hi. We have a magic cheif dyer. It turns the clothes, but it doesn't dry. Also, it has been having... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CYE4000AWW Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
