Computers & Internet Logo
Ritesh Upadhyay Posted on Sep 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hcl notebook t2050
Ethernet controller Driver has got corrupt. Also DVD Player & Writer driver has got Corrupt.Please advise remedy for the same.
David
Level 2:
Sergeant:
  • Expert 486 Answers
  • Posted on Sep 19, 2013
David
Expert
Level 2:
Sergeant:
Answers
486
Questions
0
Helped
65804
Points
866
Since you are facing multiple issues. I suggest you perform a system restore to an earlier date. There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps.
Regards
David
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Sep 16, 2008
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
kbdesign
kbdesign
  • 370 Answers
  • Posted on Mar 16, 2009
SOURCE: I have an IBM Thinkpad r60, and my hard drive was
I know that you cannot get the thinkpad on the internet, but you can download the drivers from this link from the computer you are using for FixYa. Download them to a flash drive, and load them from there to the thinkpad.
http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
Good luck
Anonymous
  • 227 Answers
  • Posted on Mar 28, 2009
SOURCE: acer extensa 5620 notebook dvd-cd rom doesn't read
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Ekse
  • 13435 Answers
  • Posted on May 03, 2009
Heres the solution to that problem.
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Anonymous
  • 4 Answers
  • Posted on May 21, 2009
SOURCE: Can not find the ethernet controller driver.
http://driverscollection.com/?file_id=37964
That should be it, Enjoy.
2answers
Hcl leaptop d9912 cdp t2050 audio drivers. i tried to search HCL website i did't get it.. pls help me
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers http://download.cnet.com/71009501-exe/3000-2108_4-120556.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don
2helpful
2answers
It doesn't work. Control panel sees the drive and driver is up to date. Drive spins, but computer can't read disk, My Computer cannot see the drive.
well i would need to know your operating system first and the exact model i will definitely be able to solve your problem for you.....what is probably wrong is my computers not picking it up because the driver has become corrupt even though you can see it in device manager it still can be corrupt the best thing i can advise just now is a system restore to the closest date that it was working that should work but i am only advising this because i need more info... i hope this helped and i hope to hear from you
1helpful
My dvd writer no reading or writing
hi there,
Does the light flash on the front when a disc is inserted or have you recently installed it as a Primary/Secondary optical drive? Plus, just as a matter of interest it will only read DVD's & read/write CD's.
Your problem could be down to a number of causes including a corrupt driver, where you will have to uninstall the driver by going into Device Manager, clicking the + sign in front of 'DVD/CD ROM drives,' right clicking on the Optical Drive in question, clicking properties/Driver Tab/Uninstall (Advanced).
This will remove a corrupt driver & when you restart your system the Hardware Manager will recognise the said Combo Drive & reinstall the driver.
If it is only unable to read DVD''s then you may require the necessary Codecs for your preferred Media Player, to support various file formats. I wish you the best of luck.
Kindest regards
Ste
The dvd drive (nec dv-5800a) corrupt driver?
Try going to device manager, and uninstall the optical drive. Reboot the comp . It should resolve the issue.
My cd writer says it isnt connected to driver
Hello and thank you for using Fixya's services.
This happens when the software's engine driver is corrupt. You can do one of two things.
Restore PC back to whenever it was working correctly or un-install and reinstall the software. It will then work properly.
Please let me know if you have any questions.
2answers
Can't read dvd inserted..it says a blank dvd
have you tried reinstalling the dvd drivers?
I would try that and see if it works.
also make sure you set to the proper region for your dvd's
you can only change the region a couple times so go easy.
5helpful
5answers
Ethernet controller driver code 28
i need ethernet controller software for compaq(model NO: sr5060il)
20X DVD/CD Writer & Rewriter. Playing a CD OK, but DVD with Windows Media Player I get picture but no sound. Using Real Player I am told that the software is not installed. I have installed the...
I think your sound device driver is corrupt. Go to control Pannel, click system,click the hardware tab and click device manager,check the sound video game controller, if there is any ! mark on the list, reinstalled it .
Grand Canyon Tech
Grand Canyon Tech
