Question about Kitchen Ranges
Jenn-Air "drop in" 4 burner range and oven (Model #88370)about 28 years old. Righthand front burner goes immediately to super-high when turned on "Low". Have tried replacing the 2-unit burner with a brand new one, but problem persists. Trouble must be in the dial switch for burner on the control panel. Waht can be done about this? F. Wampler 1406 Thomas Rd. Wayne, Pa
  • fwampler Apr 20, 2009
    Dear Kevin -
    Thanks for your response. I figured the problem was probably
    in the burner switch and am glad to learn the replacement part
    can still be purchased from Jenn-Air despite the age (29 years)
    of the range. Now, the all-important question. I am fairly handy.
    Is this something I can do myself? How do you access the
    underside of the switch control panel? (I recently replaced the
    main bottom heating coil in the oven and it is working fine.)
    Fredrick D. Wampler
    Scholar:
  • 192 Answers
Wow this has lasted for a long while. And it still has a long life. now that you have replaced the burners. You need to replace the control switch. that is where the thermostatic is once you have done this you should be cooking under control for a long time to come. good luck DFD
Posted on Apr 20, 2009
    Genius:
  • 1,847 Answers
This problem seem to be with the burner switch, that need to be replaced..
You can buy the part online from this site
http://www.cheapapplianceparts.com/oven_range/oven-range-jenn-air-maytag.html
Let me know the ....
Thanks
K
Posted on Apr 17, 2009
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Kitchen Ranges
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Stove top burners
It is not the cartridge. It is the ignition switch (sometimes called a cooktop switch) I found mine on ebay. In particular it is a faulty rear switch. Save your money on the cartridge.
Feb 10, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Whirlpool Drop-In rear burners shut off
The gas line was stuck clean nozzle w/ small neddle and clean burner set the edge of the burner in order complete gas will be burn.
Jan 04, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
