Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 machine does not drain the water
Machine spins ok but not draining the water from machine
  • 77 Answers
Your drain pump is out. Usually attached to your motor and operates when the drain cycle is engaged. It's usally a 20 dollar piece. good luck.
Posted on Apr 17, 2009
Will not spin
Error F-02 is a slow drain problem. Remove rear cover of machine after disconnecting mains cord from wall. Remove the wide pipe from the base of the drum, inside there is a non return ball valve; of course be prepared for a lot of water from here. Clear out all your junk, clean and refit carefully, as you disconnected. Keep a track of things when you are dismantling. To have access you might have to remove top, depends.
For some models: Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side (screws underneath?) and find access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl click if helped.
Apr 06, 2013 | Hotpoint Washing Machines
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
get some descaler part No C00090908 that should sort the smell as for the seal you will better off replacing it
Jan 26, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Wt960 with an F-18 what is it and how can i fix it
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma37 washes clothes ok but wont drain or spin
the hotpoint has a saftey factor built into it if the water does not drain it will not spin , the fault is the pump is blocked or broke or the sump hose is block this leads into the pump
to fix take the drain hose the grey one and put it in to a bucket and it will empty the water
if not the sump hose is blocked
if it emptys lie the machine on its side if poss with power off , if it will not lie on its side disconect the water hoses
look under the machine u should see the pump and the sump hose u can remoe this hose put lots of old towels down to catch the water check in side the sump hose for blockages
the pump this on the new models has hex bit screws on it to open check to see if it move freely it should spring back slightly
try this any problems let me know the model number
Jun 28, 2009 | Washing Machines
Hotpoint ultima wt960
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
401 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
