Question about Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
Install new code
Can't find instruction manual and need to change code on door
The master code number is on a sticker. The sticker is located on the back side of the keypad. To get to the sticker, you need to remove the lock as the sticker is facing the outside of your door again behind the keypad. There you will find the six digit code for your unit.
You can delete any code that you know of or you can delete them all and start all over with new codes.
Regardless of which model number you have, the programming is all the same. I have four such units on my property. Good Luck!
All the help you need is at the Schlage website... Go to:
http://consumer.schlage.com/customerservice/BE365_install_inst.asp
Posted on Jun 01, 2009
Bought new front doors, had schlage be 365-cam electric door lock installede on the doors, and never got the instalation instructions back from the installer, would like to change the pass code on the lock...
This is sort of easy to do, you need to unscrew the back cover here is the manual that walks you through the specific steps for whatever you want to do as far as programming. You need to scroll down past the installation instructions.
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Aug 10, 2011 | Schlage BE365-CAM BE365CAM716 Aged Bronze...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
I need to change the batteries and reset the pass code in (2) keyless locks ("Locknetics On Board"). The owner's manuals were never given, and the key (Schlage) override was never used.(No...
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (third item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Jul 06, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Hi, I have recently moved into a new home with the Schlage BE365VCAM619 Camelot Deadbolt Keypad, Satin Nickel installed in the front door. We weren't left with any manuals or anything and have no idea how...
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
Jan 10, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I need an installation manual for this product, I have changed my kitchen doors and can't connect the new door to the dishwasher, please help.
Hi
Thanks for using FixYa. Please post back with the manufacturers name and model no# of your Dishwasher so that I assist you with the installation instructions.
Thanks
Rylee
Jun 02, 2010 | Dishwashers
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
How to change code
Take the cover off the back of the unit where you are supposed to install the batteries. The instructions should be inside the cover. Hope that helps.
Jun 03, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
No instructions for reprogramming keyless remote
the chamberlain company is very nice go to sears and get number of side of box... sorry I cant remember off top of my head...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
1,469 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
