Question about Sony D-NE720 Personal CD Player
Sound problems on my D-NE720
Hi! I have this problem on my cd player. You see, when I connect my headphones to my cd player, I can only hear music on the left side of my headphone. And when I try to wiggle the headphone cable (the part near where the connection is), the sound sometimes plays at the left or at the right of the headphone. What should be the problems of this? Please help me. Thanks so much
  • 752 Answers
!st, try a different pair of headphones. If the problem persists, the jack is breaking from the PCB and will need to be resoldered.
Posted on Sep 20, 2007
I was playing a cd, then suddenly the speakers made a crackling sound and no more music. I have tries the turn-table, cassette player, and tuner...no sound. what could be the problem?
Is there any sound via the headphones? If it is normal but not on the speakers you have a faulty headphone socket.
If you turn it up to full volume can you hear anything? If you can then the main amp has failed.
Oct 12, 2015 | Audio Players & Recorders
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
I cant hear music from the headphones numark cdj 200
Since there are no headphone outputs on this unit, I'm not sure what the trouble is. Please be more specific. Thanks.
Jan 12, 2013 | Numark Industries Numark NDX200 Tabletop...
CANNOTE GET RADIO MUSIC NO SOUND
i've just finished repairing one of these Model 88 cd, from Cambridge sound. It also had no audio. I found cracked solder connections on the audio amplifier IC on the amplifier board as well as an inremittent headphone jack on the front of the radio. Try it with headphones, if you get dound try to clean the jack with isopropyl alcohol. a couple of drops inside the jack then insert the headphone connector several times to move the relay inside. Good luck. took me about two hours to resolve this with limited information available.
Sep 28, 2012 | Cambridge Soundworks 88CD CD Player
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
The sound is distorted - for example on certain songs i can only hear the instruments, and not the vocals. On other songs i can only hear the vocals and half of the instruments, the rest of the music is...
sounds like either the mp3 player or the receiver have SRS (kinda like virtual surround sound) disable or modify this setting. search your instruction manual for more information. hope this helps.
Dec 30, 2009 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sound problems
Have you tried using a differant set of Headphones? If you still have the same problem with using other headphones, then it seems like there's a poor connection on the sound card from the headphone in input to the board. If your sound card works fine through normal speakers, then that's more then likely your problem.
The cheapest solution would be to replace the sound card rather then have it repaired, as it would probably cost you more to have it repaired then what it would be to buy one depending on what quality of sound your happy to listen to.
Dec 01, 2008 | Samsung Yepp YP-P2 Digital Media Player
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
Music loud, voice low-pitched
Found your question due to having the exact problem you described. New firmware, format... loaded new music, same problem. While switching to yet another set of headphones the sound got better momentarily. The case doesn't appear loose, but squeeze right next to the lcd and lyra name and the audio was fixed. For some reason the audio was mechanical sounding and the voice was almost non-existant unless pressure was placed on the player where described. I tightened the screw in the retaining strap hole and the one under the USB connector flap and all is well for now. Good Luck!!!!
May 01, 2006 | Thomson Lyra PDP2444 53 MB MP3 Player
Sony D-NE720 Personal CD Player Logo
75 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
