Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Dishwasher i need to change the waste pipe on my dishwasher as the old one is too short. the old pipe goes up into the back of the machine, how do i get into the back of the machine and change the pipe?
  • 3 Answers
You ..dont need to get into the back.With the bottom front panel off,disconnect the waste pipe frm the pump on the right and pull it through from its other end.
Posted on Jan 16, 2008
Do you put it on cold water pipe
Yes the cold water pipe as the new models only have one supply. You connect the pipe to a cold water supply it then goes into the dishwasher and the machine heats the water up to the required temperature. Don't forget to fit the drain pipe into your waste pipe also to take the dirty water away.
Sep 06, 2014 | Zanussi Dishwashers
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
Frigidare dishwasher did not spin
  1. Waste Disposal/Sink trap
    • Empty your food waste disposal unit if your dishwasher's hooked up to one. If it's not empty, the old food inside it will back water up into your machine. Check that your sink trap isn't blocked by unscrewing it from the base of your sink if you don't have a food waste disposal unit. Make sure your dishwasher or any other appliances connected to it are not running when you do so.
    Incomplete Cycle
    • You may have opened your dishwasher's door mid-cycle before it's had a chance to drain. Check the progress indicator on your machine's control panel. The structure of this will differ depending on which Frigidaire model you're using, but it should show the point your machine has reached in its cycle. If this is the cause of the problem, close your dishwasher's door and let it finish.
    Drainage Pipe
    • Inspect the drain pipe that runs from your machine to your waste disposal unit or sink. If this is kinked or has been squashed under another appliance or a base unit, the waste water inside your dishwasher will be unable to escape. Check that water can flow through your waste pipe freely.
    Filter
    • Remove the bottom shelf from inside your machine and take out the plate covering the filter area. If you don't rinse your plates before you put them into your washer, food debris could block your filter and stop water from reaching your drainage pipe. You can unblock your filter with your fingers. Turn off your machine's power before you attempt to do so.
Feb 02, 2012 | Dishwashers
Water from the sink fills up the dish washer
I had a similar problem with a washing machine, until I replumbed my waste pipes. My Washing Machine waste pipe was attached to the down pipe just under the sink bowl. I found that the U bend trap was too high and the water level in the U-bend was at the same level as the Washing machine waste pipe was attached. So we has syphoning back into the washing machine. I moved the U bend trap down by 3 inches 7 cm, so now the water leaves the washing machine falls the 3 inches to the water level of the U bend. We now have no more syphoning back into the washing machine.
Jul 05, 2011 | Tricity Bendix 18 in. DH090 Free-standing...
Zannusi 24 911711057 serial number908805364 water from kithen sink goes back down dishwasher waste pipe into machine the ubend under sink is not blocked advice please asap thanks anthony wanford
Hello, your might have blocked kitchen drain? If not blocked, check that your dishwasher drain pipe has higher point then conection to waste pipe.
Jan 17, 2011 | Dishwashers
Water goes in then straight out of the waste pipe
The waste pipe is probably too low, this is letting the water syphon out.
Try lifting the outlet pipe higher up, this should solve the prob.
There is a line on the back of the washer, which incates the min hieght for drain outlet.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do i change the waste pipe on a Siemens SE25235 GB dishwashe?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply. once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
Jan 06, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
I want to plumb in a dishwasher but there is no waste pipe for the dishwasher to join on to
If there is a kitchen sink nearby you should be able to get a plastic waste pipe adaptor from a hardware store that simply screws in below the sink plug hole and joins to the U-bend pipework. It will have a short stub pipe on it for attaching the dishwasher drain pipe.
Hope this helps. D.
Jul 31, 2008 | Dishwashers
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Nov 10, 2007 | Dishwashers
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
266 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
