Question about Polaroid FLM-3225 32 in. LCD Television
No television without cable
I recenty disconnected cable and went back to good old regular tv--I think--- I have a rca television(1 Connector in the back and places to put the red,ylw,wht connections, I purchased an rf modulator and rabbit ears-I also have a dvdvcr combo and I can play the tapes and dvds but I can not get tv--I get a blue screen and in the upper right corner it reads tv13, it will not switch channels or anything else--my tv is about 3-4 years old---please help
  • 557 Answers
You have the TV set to cable. You need to go back into the menu. Go to the settings and change the setting where it says cable to AIR.
Posted on Sep 21, 2009
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
How many instrument and power cables in one cctv
Hi a simple CCTV one camera system is 1 pair of power wires (1 positive 1 negative) and 1 piece of coax cable with BNC connectors at both ends. (usually rg59 but RG6 is better)
Things to be aware of:
Cameras come in both 12v DC OR 24Vac configurations some are capable of both but most models available to consumers run on 12v most professionals choose 24v models.
simple adapters used to convert from regular coax screw type connectors to either an RCA connector or BNC connector are available at Radio shack. If you need more than 1 or 2 its cheaper to get them on ebay.
You can connect a BNC equipped camera to an input on your TV by using one of these adapters. *put an RCA connector on the end and plug it into one of the yellow video inputs on the TV.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
No sound
Its not your TV, call cable company, ask them to reimburst you for the days and times, you were unable to use your cable to is fullest advantage, you should get about $4.75 a day you were unable to use ur cable after the storm
Feb 26, 2009 | RCA L32WD22 32 in. LCD HDTV
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Tv trouble
Hi there!
I think you may have a problem on the tuner module. If using scart connector in your country, check the cable itself or replace, otherwise loose connections on the inside of the unit or a circuit fault. Try the cable first then a repair technician. Good Luck,JUS004
Nov 09, 2007 | Sanyo DS35510 35" TV
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Sep 29, 2007 | RCA F25432 25" TV
No cable picture or sound
only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Jun 19, 2007 | Toshiba TP50F60/61 TV
Polaroid FLM-3225 32 in. LCD Television Logo
107 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
