Microsoft Wireless - Optical - Mouse - USB Receiver
Problem for Microsoft Wireless - Optical - Mouse - USB Receiver...
My wireless mouse freezes
By dihausmann on Apr 17, 2009
It works for a while and then freezes. If I turn it over the red light is flickering very fast instead of a steady signal. After a few minutes the fickering stops and it works again.
Same Problem
Apr 17, 2009
-   I have the same problem with Logitech Wireless mouse -   philmik
Best Solution
posted on May 31, 2009
Very Helpful)
mackp
Rank: Apprentice
Rating: 100%, 2 votes
I had a similar freezing problem with a wireless Logitech mouse and also a problem with the wireless keyboard, sometimes keystrokes would not register and sometimes they'd repeat a dozen times.
I was not able to fix the problem, so I got a Microsoft wireless mouse and keyboard, hoping it was a driver conflict that wouldn't affect both products. Wrong. The exact same thing happened to the Microsoft mouse and keyboard.
The cause of the problem turned out be that I had the receiver plugged into a USB hub along with several other devices. Moving the receiver to one of the USB ports in the back of the PC fixed the problem.
Apparently these wireless desktop devices don't like sharing USB resources with anything else.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 05, 2009
Not Rated)
kayla204
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem. The mouse was working intermittently and it wasn't the usual run down batteries symptoms you can fix by clicking the green button and eventually replacing the batteries. After reading the solution above about the USB ports I realized it might have to do with the new printer/scanner/copier/fax I hooked up yesterday, so I reached down to the telephony modem I messed with yesterday, moved it back to the way it was before, tightened up the cable, phone, and power connections, and lo and behold, the mouse worked perfectly again. I am no techie, and I have no clue why a wireless mouse would respond to messing with cable, phone, power, or a modem. Maybe it has something to do with the line of sight of the optical scanner on the mouse, but I doubt it because of the solver's USB solution. I'm just glad I don't have to go buy a new mouse!
Was this helpful?
Yes
No
Popular Solutions for Microsoft Wireless - Optical -
Questions and Unsolved Problems for Microsoft Wireless - Optical -
Do you recommend Microsoft Wireless - Optical - Mouse - USB Receiver (1010104281)?
Answer
Answer
my tropix laptop motherboard blacked out and can not display, yet when i switch on , the power light... (More)
Answer
My keyboard is not working. On my reciever, the F light is on and I cant get it off.
Answer
when i connect the receiver to the usb port i receive the message:"usb device not...
Answer
I need driver for my tropix web cam. The web cam is functional but not seen by the machine. what... (More)
Answer
On boot up computer stops and reports no mouse found, asks hit f1 to ignore or del to inter set up... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Wireless - Optical -...:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14881
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
