Question about AEG Lavamat W1050 Front Load Washer
WASHING MACHINE DOOR SEAL REPLACEMENT
HAS ANY ONE ANY IDEAS ON HOW TO CHANGE THE DOOR SEAL / GASKET ON AN AGE LAVAMAT W 1050 ELECTRONIC?
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
    New Friend:
On of or sockes went it to the machine and blocked the drum
Posted on Mar 21, 2010
SOURCE:
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
I need to change the door seal, any advice??
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 11, 2009 | Siemens WM5487A Front Load Washer
Repacing the door seal on my oko lavamat washing machine
this could be out of the door tension clip you might see it in this video
Sep 04, 2009 | AEG Lavamat 88840 Front Load Washer
Aeg lavamat w 1050 electr. rubber problem
dears, thank you for repling of my subject , i solved the problem with replasing other new rubber .
thank you again for your interesting
Mar 23, 2009 | Kenmore 22422 Top Load Washer
Door seal damaged on Lavamat 830
Yes, you can replace the seal. See my article http://www.fixya.com/support/t1543617-door_seal which should give the guidance that you need
Feb 15, 2009 | AEG Washing Machines
AEG Lavamat W1050 Front Load Washer Logo
496 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
