Question about West Bend 82306 Stir Crazy® Popcorn Maker
Rod will not turn when popper is plugged in
DOES THE MACHINE HAVE REPLACEMENT PARTS? IS IT WORTH THE TROUBLE TO REPLACE PARTS. IS THERE A BETTER POPPER THAT WOULD LAST MORE THAN 4 MONTHS?
    President:
  • 1,489 Answers
I once tried to get parts for a West Bend popper with no luck. I just kept using it without the stirrer.
I would say from a pure economic standpoint, you're better off getting a new one. I don't know that one brand is any better than another -- it's just potluck from my experience.
Posted on Apr 22, 2009
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Model 5916052 popcorn popper
Star 59 is an 8oz popper, they stopped making them in 1992. Parts are becoming very expensive, usually better to dispose of the machine.
I have some used parts available, depending on which ones you want, or you could try partstown.com for Star parts.
Jun 12, 2013 | Star Manufacturing Kitchen Appliances -...
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
I only ned the bowl for my stircrazy popcorn popper. Is it possible to buy one and the cost please.
We can't sell you the bowl at Fixya as we only can help with instructions and so on. What I can help you with is where and who to contact about the bowl.
I believe your popper is made by WestBend. So you have a couple of choices. You can look for a repair shop that will have replacement parts. These are not that common these days but they are around. You can search on the net for them and I would talk to the store you purchased the popper from and ask where you can get parts. They may have a local repair depot that will be able to help. If that doesn't get you a source then you need to try Westbend.
Go to http://westbend.com/ and click on the support tab. Then click on replacement parts then Westbend and then popcorn popper. Select your model and it should now display all available parts. Unfortunetly the replacment parts tend to be power cords and covers so there may not be a bowl available for your model. It is still worth using the Westbend contact information and asking if they have one just in case.
Aside from other sources such as ebay or thrift shops you may not be able to find a bowl. And what you have to keep in mind is the replacement cost of the bowl plus shipping if you can find one. You may find that you will have to buy a new popper as it would cost less than getting the bowl.
Sep 18, 2011 | Microwave Ovens
Replacment parts
Did you find the piece to your popper? I just dropped mine on the floor and broke it, so if you still need that little piece, I have it.
May 21, 2008 | Back to Basics Disney Popper PD5 Popcorn...
Popcorn popper
I am also looking for replacement parts for my ccp-509, specifically the kettle plug connector (female)
Sep 28, 2007 | Kitchen Appliances - Others
West Bend 82306 Stir Crazy® Popcorn Maker Logo
447 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
