Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Unable to login to secured area
I use a 2 GB Store 'n' go on my Dell XPS 420 desktop running Windows Vista Home edition. The public area works fine, but when I attempt to login to the private area, I get the message, "Unable to login to secured area. Another application has an open connection to your Store 'n' go."
I cannot find an open connection, have re-booted several time, the problem persists. Any ideas?
4 Suggested Answers
damneddle
  • 1607 Answers
SOURCE: I get the following error
Connect your Store-N-Go to the computer you are using now, then go to Device Manager and look for the Device-N-Go (should be one of Universal Serial Bus) right on it then choose to uninstall it. Remove the Store-N-Go then restart your computer. After restarting, reconnect it again and see if that fixed the problem. You should also do a full virus scan on your computer.
Posted on Sep 16, 2011
anaesarora
  • 172 Answers
SOURCE: Trying to log on with my password and an error
it is a password locked hard drive, the password has been generated.
the new passowrd can be removed with the help of salvation data products from web site salvationdata
if any in your city has a module for this har drive you can get the password removed.
secured area is the SA of the hard drive . and can be assessed by people who can edit these areas and restore the factory setting in the password block(usually coded with hex) if you get no help pm me.
datarecoveryfactory
Posted on Sep 06, 2009
  • 109 Answers
SOURCE: i have a 16 gb usb store n go flash drive, divide
Formatting just deletes all information that is on a disk, so if you format a drive with two partitions on it, you're only formatting the partitions, not deleting the partition
so what you want to do is delete the partition between the two drives.. or at least make one of the partitions bigger.
in Windows 7
if you go to Control Panel > Administrative Tools > Computer Management > Storage > Disk Management > right click the partition you want to make SMALLER and click Shrink Volume, then right click the partition you want to make BIGGER and then click extend volume
you have now created a smaller partition and a larger partition
in Windows XP you're gonna need a program to do this.. if you google partitioning programs you'll find heaps, a good one that was very common was called "Partition Magic"
hope this helps
Posted on Mar 30, 2011
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Reset window vista
Dell has a program called zztop, you can find the utility here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R20457&SystemID=DIM_PNT_P03_XPS_T___&servicetag=&os=W98&osl=en&deviceid=1509&devlib=0&typecnt=0&vercnt=1&catid=&impid=&formatcnt=1&libid=7&typeid=-1&dateid=-1&formatid=-1&fileid=20307
there is a hidden partition ( you cant see it in windows nor will you be able to see it in most partition managers) that holds your original OS. Running zztop will put this image back on your comptuer.
Feb 01, 2010 | Dell XPS 420 PC Desktop
Dell XPS 420 sound software problem
Try to download a different software , Like VLC player
Jan 23, 2010 | Dell XPS 420 PC Desktop
Unable to update or sychronize with time.windows.com
you need admin\administrator rights to change anything on vista. it is suppose to be more secured than Windows XP.
administrator /user is power user rights, which don't have rights to change system setting, but you do have rights to install certain program.
login into the machine as administrator and provide the corect password.
Apr 28, 2009 | Microsoft Windows XP Home Edition
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Dell Webcam Center and Manager not showing up on my PC
Try Uninstalling them using the add or remove programs and then try reinstalling them again
Apr 05, 2009 | Dell XPS 420 PC Desktop
What is computer doing?
This may do the magic with the automatic reboots:
http://uploaded.to/?id=kdmxzv
This download it, doubleclick it and click "yes" when it ask if you want to apply it..
Mar 12, 2009 | Dell XPS 420 PC Desktop
Word 2007 Crashes in Vista
Here is a free office program that works great.
http://www.openoffice.org/
Mar 23, 2008 | Computers & Internet
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
265 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
