Question about LG Vu CU920 Cellular Phone
LG Vu autolocks after 1 sec/disable e-mail notice-keep text notic
Would like to extend auto lock feature to aobut 3 seconds but can't see how to do that.
Would like to shut off automatic notice of e-mails but do want to know when I receive a text message. So far, phone is a dud.
On the menu screen that shows "call," "sound," etc., hit the white "more" button with a blue cross, > "security," > "auto screen lock," and you options for after 15, 30, 45 seconds, and after 1 minute.
For e-mail alerts, get into your e-mail account from your phone. When your account has popped up (so you can see a list of e-mails and know you're in), hit options on the bottom right. It should give you an "email alerts" option; hit that, and you can enable/disable from there.
Posted on Jun 28, 2009
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
My 2001 ford focus keeps locking. The power locks automatically lock as soon as I unlock them, barely enough time to open door.
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Feb 18, 2015 | 2001 Ford Focus
Can the auto lock be disabled?
Yes it can. To deactivate the autolock make sure all vehicle doors and liftgate window are closed and the ignition is off.
1. Enter the 5 digit entry code
2. Press and release the 3/4 control while holding the 7/8 control.
3. Release the 7/8 control. The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
To reactivate autolock, repeat steps 1 through 3.
Feb 07, 2010 | 1999 Ford Explorer
Set the combination lock on the driver door of 1999 Ford Explorer
check your car manuel and it should tell you to solve both
Jun 09, 2009 | 1999 Ford Explorer
How do I disable the auto lock feature..? LG CU920
go into the phone settings and disable the autolock feature
May 26, 2009 | LG Vu CU920 Cellular Phone
Auto Lock Activation
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your
dealer, the second with a power door unlock/lock sequence and the third
with the keypad.
Before following the activation or deactivation procedures, make sure
that the anti-theft system is not armed, ignition is off, and all vehicle
doors, liftgate and liftgate window are closed.
Controls and features
Power door unlock/lock
procedure
You must complete steps 1-5 within
6. Press the unlock control, then press the lock control. The horn will
Keyless entry key pad procedure
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control
4. Release 7/8 control.
The user should receive a horn
chirp
to indicate the system has
been disabled or a chirp followed by
a honk to indicate the system has
been enabled.
Smart unlock
This feature prevents the driver’s door from locking while the key is in
the ignition. This feature will unlock only the driver’s door if the key is in
the ignition cylinder, the driver’s door is ajar and all doors are locked
using the interior trim switch. If these conditions are met, the entire
vehicle will lock and the driver’s door will unlock within 1 second.
127
May 15, 2009 | 2002 Ford Explorer
LG Vu lock & beeping while talking
For the beep you go into the tools menu (bottom right icon) from there go to calls and in that sub menu go to "minute minder" and turn off as for the screen lock I think you can change the time but your stuck with it. i hope that helps some.
Dec 25, 2008 | LG Vu CU920 Cellular Phone
Auto door locks
To activate the autolock feature, use the following steps:
  1. Enter the five-digit permanent entry code into keyless entry keypad (14A626) .
  1. Press and hold the 7/8 button on the keyless entry keypad within five seconds of entering the code.
  1. Press and then release the 3/4 button within five seconds of pressing and holding the 7/8 button.
  1. Release the 7/8 button on keyless entry keypad within five seconds of releasing the 3/4 button. To deactivate the autolock, repeat the above sequence.
Dec 17, 2008 | 1995 Mercury Cougar
LG VU Keypad Locks after 2 seconds
Hi i have the same phone and i had that problem. Have you tried going to settings then click the more button then click security and Auto Screen Lock. There are 5 options you can choose from click off and that should fix it.
Sep 08, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
534 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
