Question about Sony Ericsson W200i Cellular Phone
My mobile get slow then before, even the memory is only about 20 % filled.
  • 3 Answers
Contact any nearby sonyericsson service center...
Posted on Dec 16, 2007
6ya staff
SOURCE:
Slow running, take long time to open programs
download iobit advance system care 6 and run it and it it will show you whats slowing down your computer
Jan 05, 2013 | HP EliteBook 2530p Notebook
My nokia n73 having quite problems like you know very slow and not so much fast as others nokia sets. Always internet will be blocked or shows connection error while browsing please help.
first free your phone memory by formatting it .... code is *#7870#.... note you shold have full charged battery and the phone should be connected to charger......... phone will restart and formatting may take 5 to 10 minutes........ this will free all your phone memory.......... now install the browser you use.... i.e opera mini....... in phone memory......... dont fill your phone memory........its the ram you utilise......... your phone will work faster......... it is slow from other nokia multimedia sets because it has a maximum ram of 44 mb that to can be used to a extent of 30 mb......... also use netquin mobile guard to enhance your phones performance
Jul 01, 2011 | Google Computers & Internet
China iphone high speed sim solution
Sir kindly explain what your problem is ? Please reset your mobile to factory setting if you have slow working . The chinese mobile os slows down with more amount of data put into the phone memory aswell as memory card . so Please leave a 20 % empty space on both and try the same . Else please flash the system by the vendor and enjoy . Thankyou
Jun 05, 2011 | Dual Electronics CECT P168 Cellular Phone
Theres a code "LF" beeping....
Hello there and thank you for choosing fixya
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
  • Slow Fill- low water pressure reduces the speed at which water flows into the machine.
    • Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
  • Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
    • Contact the water company to verify the pressure being supplied to the house
  • Error Codes- LF for long fill or FH for no water detected.
    • A plumber may need to be consulted if the pressure is found to be too low.
May 16, 2011 | Washing Machines
My phone is getting toooooooo slow the days.....its just three months old only now...why is ths??
Hello there!
Usually, huge files of movies, mp3, or even viruses can slow up your mobile unit. I suggest you install an application for antivirus that compatible to your mobile phone.
Try to remove some of the files such as mp3, or video clips, or even movies. Or you may expand your external memory card to a higher capacity.
Hope it helps,
fossildude
Mar 17, 2011 | LG GT540 Cell Phone
The mobile hangs
First, what's your mobile phone? Have you tried updating the firmware? Maybe the phone memory is to filled that's why the phone's slow.
Mar 05, 2010 | Nokia 6600 slide Cellular Phone
N73 hangs/works too slow
My N73 M phone hangs, sometimes doesn't ring and takes 15-20 secs to navigate between functions. Pls help with a solution.
i have already reset the phone by using the *#7370# code, but it still remains the same....
Help me with a solution.....
Mar 30, 2009 | Nokia N73 Cellular Phone
Nokia N95 Orange Too Slow.
hi.. the reason for ur slow operation of ur mobile might be due to some software problem...The only way to get rid of this problem is that to format ur entire mobile...Or the other one may be due to full use of ur memory card...I mean for example if u are using 1 gb memory card u are not suppose to fill ur mobile completely for 1 gb.. try to some keep some memory space which will ease ur mobile opeartion...
thank u
Feb 01, 2009 | Nokia N95 Cellular Phone
Phone freezing
hi all viewers `this is a good tip for your nokia 5310. well your phone is freezing cus you have to much memory on the phone the phone has a memory on its self witch is 20 mb. if you fill up like 15-20 mb it will slow your phone down or freezing completely. you can fix this by moving files to a memory card on the phone freeing up space i recommend you store 5-7 mb on phone memory. 100% success if not you have a problem
Jun 27, 2008 | Cell Phones
Sony Ericsson W200i Cellular Phone Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
