Hi there. When you connect an external display, your laptop clones your desktop to the external display, including resolution settings. First you need to check what resolution settings the plasma can display. If your laptop is set to a resolution that the external monitor can't display, then you will lose the display once the resolution settings are loaded. You can change the laptop resolution in your Display Settings.
If you don't know what settings the external monitor can display, just open your Display Settings and set your laptop resolution to 1024x768. Almost all new monitor/tv's can display it. Connect your external display, and see what happens. If it works, but the resolution doesn't look right, then just move the resolution along one more, until you find one you're comfortable with.
N.B. Some monitors/tv's "jump" resolutions. i.e. the monitor can display 1024x768, 1300x768, but not 1280x800.
Another thing to remember is that if you are running Windows Vista, you may need to check that the Windows Mobility Center recognises the external display that you are trying to use. You can find Windows Mobility Center by clicking Control Panel, then Mobile PC. It should now be listed on the screen.
Let me know how it goes, and if it works, please rate.
Tim
Did you try going to the display setting's to extend your window's desktop to a external monitor?
