Question about Canon PowerShot A630 Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Okay so my Canon PowerShot A630 was working fine one minute, and then next it turned off randomly, and the lens locked in a half open position. Every time I try to turn it back on it squeaks, beeps 6 times, and says "lens error, restart camera," then turns off again, what do I do? Thanks...Brendan Carnevale.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Apr 18, 2009
SOURCE:
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
My PowerShot A650 IS...the lens opens and closes
try charging the batteries to full when using the camera, if that did not work, update the firmware from CANON.COM.
if that also did not work, you need to visit the service centre as it could be a CCD problem or a shifted lens.
Aug 21, 2009 | Canon PowerShot A630 Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Canon lens cover won't open
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Canon powershot a630 lens is stuck
My lens was stuck inside the camera and would not come out when I turned the camera on. I could hear a sound but nothing was happening with the lens. I used a dental pick (small sharp pointed object) to pull at the lens and it came out and seems to be working fine. Just tried it a couple of hours ago and It seems to be OK.
Dec 09, 2008 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
321 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
