Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Asking for driver
Dear Sir, When I insert the cruzer micro 2.0 Flash drive in USB port it asks for driver. please send me the driver or suggest the solution as I have windows 98 OS
  • Anonymous Apr 02, 2008
    i have windows 98 and a USB port.but every time i pluggin a flash or mp3 it asks for a driver.so please tell me how i solve this problem because i can't help working without a flash.
    Brigadier General:
  • 6,966 Answers
Hi, Download and install Win98SE USB driver (http://www.sandisk.com/assets/file/downloads/oem/oem-ufd-98-driver.exe). Hope this be of help. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 19, 2007
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use a sandisk cruzer micro usb 2.0 flash drive
insert your 2 gb cruzer into a usb port click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them
or if you are downloading from the internet once the program/files starts to download an option will open and ask where you want to save it or run it also browse click on the browse to save it to your 2 gb cruzer
hope this helps
Jul 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
Jul 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i retrive my files on my u3 scan disk
most zip drives come with the software drivers needed to open and read anything stored on them if after plugging it into a usb port you do not get a conformation chime that something has been hooked up and than another prompt asking how you would like to view the files your usb port of choice is most likely the issue so I would suggest trying another port
Mar 30, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Dont want to format my flash drive
Sounds like all the connections are not . . connecting.
If the computer recognized the device but can't get the directory structure, it will ASSUME it's not formatted and suggest a format.
Check the connections to be shure the drive is fully inserted in the USB port, and that the connector is fully extended, and free of any obstacles.
Hope this helps.
Dec 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My flash drive keep asking me to format it
Check on your usb port, it is the one causing the problem.
To test, try plugging the flash drive into another usb port. If it did not ask you to reformat, then it was your USB port.
Kindly rate this solution.
Aug 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
U3 2GB Cruzer Micro wont work on my vista laptop.
Hi there, I found the solution (for all 4GB flash drives).
Initially when I plugged in my PQi 4GB flash drive with Windows Vista,
there was an error message involving " Can not find the drivers needed ... "
Simply download & install "Windows Vista Service Pack 1"
it is about 444 MB in size.
The whole process might take about 2 hours to install,
but it is worth it.
These are the links where you can find your download:
http://technet.microsoft.com/en-us/windowsvista/bb738089.aspx
OR
http://www.microsoft.com/downloads/details.aspx?familyid=090DEAF6-2EAA-4AAA-8B3B-2E199DB4A97D&displaylang=en
It works perfectly... good luck now...
Sep 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
294 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
