Back to:
Tags:
Panasonic Lumix DMC-TZ1 Digital Camera
'Turn camera off and turn back on' message (by 8 users)
posted by faltron on Sep 17, 2007
I have a Lumix DMC-TZ1 (had it for just one year)and when I went to turn it on at first it was ok but if you tried to zoom it would be blurry, then after a few mins it would not show anything on the screen apart from the message 'turn camera off and turn back on'. If viewing old pictures there is not a problem, but if you put it on the taking pictures mode this message comes up. Turning it off and on does not fix the problem. Is there a problem with the lens?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by bigdavebut, posted on Sep 20, 2008
Lumix TZ1
Camera is 15 months old
Message Turn camera off and on again
Can still review old photos, but will not take photos in any mode
Seems to be common Lumix problem
Comment by Guest, posted on Aug 12, 2008
Whenever I turn my camera on I get the message please turn camera off and then on again. Nothing works.
Comment by Guest, posted on Jul 11, 2008
AVOID PANASONIC! My TZ1 is 14 months old, ie 2 months past warranty, and on turning on, it invites me to "turn power on and off", which does nothing. On holding it to my ear I can hear faint clanking and whirring noises so it's probably to do with the lens movement. This is clearly a TZ1 problem, but Panasonic merely refer me to a repair outfit, who will repair it , at a price. Cheaper to buy another camera, this time not Panasonic.
Comment by guscos, posted on Jul 08, 2008
I have a Lumix DMC-TZ1 (had it for just 14 months)and when I went to turn it it would not show anything on the screen apart from the message 'turn camera off and turn back on'. If viewing old pictures there is not a problem, but if you put it on the taking pictures mode this message comes up. Turning it off and on does not fix the problem. The local dealer on Panasonic (LIMA PERU) charge me $85 to fix it they said the lenses had got dust ¿? Its worth repair it
Comment by muerte2vida, posted on May 24, 2008
same stinkin problem... =P
Best Solution
posted on Jul 13, 2008
FixYa! (100)
mama maria
Rank:Apprentice Apprentice
Rating: 100%, 5 votes
TRY DROPPING THE CAMERA -- YOU HAVE NOTHING TO LOSE!
I was heartbroken to learn that my Lumix DMC-TZ1, which I purchased 2-3 years ago, had died -- right during my daughter's dance recital, for seemingly no reason. Tonight I was surfing the web researching replacement cameras (many brands), and I realize that I feel like there is no real "history" on the camera that's any worse than any other camera on the market, including the Canon Powershots, which are all the rage right now. So I started researching on the Fixit site other cameras for possible problems.
What I found is that all the cameras have funky messages (Sony and Canon included!) that result when he camera has been dropped or the lense has somehow been altered. So I read all the different "solutions" and then came up with my own:
I decided that the lense needed to be un-jammed. At this point, if the camera was useless to me, I might as well take a chance and try to unjam it. So I did!
I held the camera about 3-4 inches from a table top. Then I simulated a "drop" (without the case) that was gentle enough that it wouldn't smash the LCD but that would maybe make the lense unjam. (Note: I couldn't SEE any problem with the lense; this was just a hypothesis I couldn't go wrong trying.)
Each time I put the camera on, tried to modify the zoom (a function which normally makes me get the error message forcing me to turn the camera off), and then got the message. BUT the 3rd or 4th time: TA DAH! NO MESSAGE! INSTEAD, A SHOCKER: I WAS ABLE TO MODIFY THE ZOOM! AND THEN I TOOK A PICTURE! AND VIDEO!!!!
So my camera is back! And I also have discovered that the flash problem I had started to have previously has now seemed to have gone away also.
My advice is to just TRY! You have nothing to lose: try "dropping it" back into shape! I know it sounds crazy -- but I just saved at least $200 by doing this!
Mama Maria in Burke VA
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 'Turn camera off and turn back on' message:
I don't want to Accept this solution
Solution #2
posted on Jun 25, 2008
Helpful (85)
tadm
Rating: 85%, 1 votes
I am frustrated with all the problem.
I think that the microchips are programed for operation for few months only.My lasted 13 months.As soon as warranty expired.
There must be self destructive program built in to this cameras. So we are encourage to support continuation of the company by purchasing new product. Thanks
Thank You!
Solution #3
posted on Oct 06, 2008
Not Rated (0)
bigdavebut
Rating: 0%, 0 votes
Scarily enough, dropping the camera from about a foot onto a carpet appears to have sorted the problem
Can the camera be trusted in the future though without a technical solve?
Thank You!
Solution #4
Not Rated (0)
muerte2vida
Rating: 0%, 0 votes
i tried dropping it; it did not work.
Thank You!
Solution #5
posted on Oct 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
thanks very much maria! dropping did the trick for me. so glad to have my camera back!
Thank You!
Solution #6
posted on Sep 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
for me, i tried dropping it from about 2 feet onto a carpet. Nothing happened the first 2 times...third time lucky, it started working again!
So if all else fails, dropping it is worth a try. (believe it or not, this also worked for my 2nd Gen Ipod!)
Thank You!
Can you Help with these Digital Cameras problems?
My flash does not work . It has been working in the past....
Whenever i open my camera this message is seen on the...
Hi I've moved out of my house for major renovations and...
I have a panasonic lumix dmc-tz1 and I cannot copy the...
I got an Olympus Stylus 760 digital camera off ebay for...
7 Other Users Have The Same Problem - Continued
Comment by rainyday80, posted on Nov 04, 2007
I'm having the same problem. We hadn't used the camera for awhile, and I had never seen this error message before. Any input would be greatly appreciated.
Comment by danitoh, posted on Nov 04, 2007
I've had my TZ1 for about 9 months and it has a similar problem. The "turn camera off then back on" began appearing occasionally, now it happens every time the camera is turned on (except when I just want to view pictures) thus I can't take any pictures with it at all. It makes clicking noises in the lens area for a 1/2 second before the "...off...on..." message appears.
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
