Question about Samsung SyncMaster 740N 17" LCD Monitor
Monitor's blue light is blinking when i turn it on
I left monitor on for a few days non stop and turned all "hybernations" and screen avers off in power management.. after i came back i saw monitor blue led blinking and there is now a noise coming from the casing of the monitor.. humming-like noise....
i thought monitor had died bla bla but somehow after a few weeks i tryed to turn it on and after 15 mins the monitor didnt blink anymore as if it woken from hybernation... now allways when i turn pc on i have to wait 15+minutes and spam keyclicks so that the monitor awakes from "sleep"
wtf is wrong with it any1 pls help?!
sorry for my poor english..
  • ted1430
    ted1430 May 11, 2010
    Have you tried this display on another PC? The issue may be with the PC rather than the display.
5 Suggested Answers
  • 34 Answers
SOURCE: No picture LED Flashes
I just did this to a friends monitor as well, a different model and not much different in build. I think you might have 3 screws on lower back side of cover. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest.
HOW TO OPEN A SYNCMASTER2.gif 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable(if you need to remove it), two clips super close to where the sets of wires come around the housing and into the panel. Unhook the 4 plugs(blues and pinks)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
aae8fab.jpg The capacitors top-plain should be flat(not rounded) and there should be no color whatsoever coming through the top of the cap lines(google "bad capacitors"). The specs of the cap are on the cap. The 2 caps cost me $4.00. Now keep in mind there are hazards to this.Google them;)
Posted on Nov 18, 2009
  • 1684 Answers
SOURCE: samsung 214T wakes up from hybernation flickering
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 27, 2009
lordrussell
  • 47 Answers
SOURCE: Hey Experts! I need assistnace. My Samsung 2043BWX
Actually, the ultra high voltage 'charger' for the florecence (a.k.a. your back light)has gone Kaput...
If your lucky, someone will have a monitor like yours that has the back light come on, but no picture (should get a similar blinking light situation, but a different code. Like... blink, hold, blink blink, hold, blink). In this situation (if your comfortable doing it) you can swipe the exciter from that monitor and put it in your monitor. Obviously this is a more economical way of repairing the monitor.
Just to be on the safe side (as the repair is blindingly easy. 6 screws, pop out, pop back in) DON'T touch any of the back side components. You WILL shock the supreme **** out of yourself. Between the heavy duty capacitors and the ultra high gain transformers on those things you could jump start a bus. So don't be fooled... those little transformers pack a mean sting.
Hope this helps...
Posted on Oct 11, 2010
  • 1684 Answers
SOURCE: Samsung SyncMaster 731B Monitor blinks on and off.
It sounds like you have bad capacitors on the power supply board. The capacitors in the power supply filter the power, when they fail the power supply can not maintain operation. The blinking is caused by the power supply starting up, shutting down and restarting again. The monitor is repairable, you will need to replace the capacitors on the power supply board. 8 capacitors will need to be swapped out. Here is a link to a repair kit with the correct parts.
http://www.ccl-la.com/catalog/product_info.php?products_id=215
Posted on Apr 20, 2013
Projector blinking blue power light. non stop!
check the lamp Please
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 13, 2014 | InFocus Office Equipment & Supplies
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
Westinghouse LCM22w2 Monitor
I'll buy it from you. I just need a non-cracked LCD from this monitor. It doesn't even need to turn on. You can e-mail me at rallis@gmail.com
Jan 30, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Toshiba satellite pro u300 unexpected shutdown
You should contact Toshiba as this machine is most likely under warranty.
Dec 24, 2007 | Computers & Internet
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
410 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
