Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite bp250/170mph leaf blower will not idle.
Small gas leak when running
Posted on Dec 24, 2009
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
Leaf blower will only run on half choke, & wont idle
the exhaust side of the engine is clogged with carbon. clean the carbon from the port and spark arrestor screen and it should go away. to preveent this again run your unit at full throttle all the time or at idle never inbetween
Feb 20, 2010 | Homelite 'Yard Broom' Leaf Blower
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
My leaf blower only runs on idle only when choke is close. i clean the carb. 2 times and i replace the muffler
I have found that most of the homelite hand blowers have a tendancy to loosten the cylinder bolts, that causes a low vaccuum situation thru the carb and needing more fuel to run. I would recommend you completely dissassemble the engine and replace the cylinder gasket, Use the blue loc tight on all the bolts. Any of these engines that dont have a thru crankshaft to dispurse the vibration, tend to vibrate all the bolts loose.
Nov 01, 2009 | Homelite 'Yard Broom' Leaf Blower
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
1,702 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
