Question about SimpleTech (STUU2F35120) 120 GB Hard Drive
My simpletech 120 gb hard disk is not detecting over my pc what to do?
  • 432 Answers
Right click on my computer --> manage --> disk management
does it detect there ?
Also what about in device manager ( right click on my computer --> properties --> hardware tab --> device manager
Posted on Apr 17, 2009
I have a SimpleTech Pininfarina 120 GB external hd that my laptop is not recognizing
Hmm, go to Start, Control Panel, Administrative Tools, Disk Management. Then look or scroll down right hand panel to find your disk. If it is there you could RIGHT click on it and assign a new drive letter such as Q or R.
If it's not there your external disk could be faulty, the power supply transformer or power cable could be faulty or it could be the USB cable.
If all looks OK you probably need to contact a disk recovery specialist such as DATA365. http://www.datastor.net.au
Dec 10, 2013 | SimpleTech Computers & Internet
My computer won't recognise my 120 gb simpletech harddrive unknown device and driver software not installed
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 14, 2011 | SimpleTech (sti-u2f36/120) 120 GB Hard...
Solve Your SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Blue lights are not on. Windows 7 does not recognize. I think driver is not installed. Pl advice
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jul 04, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
I deleted files from my simpletech 120 gb and now no computers recognize or will open the drive? Do I need to reinstall drivers?
While deleting files your hard drive files also have been deleted so you just re install and try it your probleem may be solved
Aug 27, 2010 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
I could not hardisk detect on pc when decting hardisk,please boot another disk
Check that the "data" and "power" cables to the disk-drive are fully-connected to the disk-drive.
Check that the "data" cable is fully-connected to the motherboard.
Enter BIOS SETUP, and check that the motherboard has detected the disk-drive.
Otherwise, your disk-drive has "died", and must be replaced.
Aug 01, 2010 | Samsung (SP1203N) 120 GB Hard Drive
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Error to Detect, hardisk must be formatted
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Mar 12, 2008 | Computers & Internet
SimpleTech (STUU2F35120) 120 GB Hard Drive Logo
143 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
