Question about Garden
Starts fine, but will not continue to run. Looks
Starts fine, but will not continue to run. Looks like it is getting air in the gas line. It is just out of the box and has not been used. The gas and oil is just purchased also.
  • maryk62 May 04, 2009
    If it was possible to retrun the trimmmer, I would not have even looked for a solution online.
SOURCE: Gas & oil in air filter box
P.C.V (positive crankcase ventalation) valve is bad.
Posted on Apr 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: CS30 Ryobi trimmer dies when I press throttle!
Yes. You just need to do a simple carburetor cleaning. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is in carb. is free of debris. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
#1 Taper
  • 1041 Answers
SOURCE: mower starts fine, however have to keep priming
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or jet in carb. These portals can become blocked. you may need to replace the diaphragm. Reassemble and start.
(NOTE:If the carburetor parts are more than four years old, and depending onthe use, you will need a new carb. kit if the cleaning doesn't work.)
Jim
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Posted on Jul 08, 2009
  • 138 Answers
SOURCE: craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Posted on Aug 17, 2009
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Tao tao kid tv won't stay running
Could be a clogged fuel filter, or clogged air filter, or trash could've gotten into the carb. Starting with fuel filter 1st and make sure you getting good gas flow to the carb. Does it have a petcock for the gas on/off? Is it operating properly?
Dec 25, 2013 | ATVs
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 | Garden
Ford truck idles fine but sputters and dies when gas is increased
I have a 1989ford econoline motor home I live in Victoria Australia the problem I have is that it runs on gas and petrol there is a part that fits on air hoses from carnie to air cleaner it looks like a set of burn oculars 2hoses fit in one endadnd 2hoses at the other end we can not find the part any where in Australia
Feb 17, 2012 | Ford Econoline Cars & Trucks
14.5HP B&S on Craftsman Lawn tractor.Carb clean, gas fresh, fuel solenoid good. Runs when gas squirted into carb. Won't **** fuel from bowl and continue running.
blow air back tru fuel line 2 c if it blocked if dat ok check ruber manifold 2 c if theres any craics cud b drawn air 4m there. also try pressureing your tank 2 c if starts if none probs needs rejetted
Aug 14, 2010 | Garden
'93 Volvo 960 wagon starts with a shot of ether and continues to run fine; however, will not start without ether (just cranks). Any ideas?
if diesel it is caused by low compression, rebuild it or live with it
if gas you may have a air leak, vaccum line open, or choke not operating
does it start easy after it is at operating temperature
Nov 22, 2009 | 1993 Volvo 960
It starts but will not continue to run. It needs
Too much air is getting into the cylinder. It probably involves a gasket and/or loose screws.
Check to make certain that the connection between the carburetor and engine is tight. A loose screw can allow air to infiltrate around the gasket and foul up the air/gas ratio.
Oct 10, 2009 | Garden
I have a homelite xl12 chainsaw it starts and runs fine untill it gets warm about 5/10 mins of run time.....then it dies or if it stays running no high revs cuts in and out.... also if you take gas cap off...
The engine is running hot. A build up of chain lube/saw dust/dirt is likely blocking cooling air to the cylinder cooling fins (and gas line and carb) causing the fuel to boil (vapor lock)
Compressed air, played around openings in the shroud, will sometimes remove enough of the obstruction to help and is worth a try. Best solution is to split and remove the case/cover, after which, the engine and shroud can be throughly cleaned. Be sure to stuff a clean rag in the carburater throat to keep debris out.
Sep 27, 2009 | Garden
Lawnmower starts but won't continue to run
Jun 30, 2009 | Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
