Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Had power outage while tv was on. When power restored I turned on tv with remote. TV sounded like it went on but no picture. Only timer light lashing. Sony Wega older model 27" Please help, thanks
  • astrid prieto May 11, 2010
    TV causing outage at your home or lightning striking?
    Sergeant:
    Champion:
  • 318 Answers
Next time dont leave your tv pluged on power, the power supply got burnt, check your power supply on the following components
fuse, power transistor, zener diodes,also rectifier diodes
if you can manage do it at home
or take it to a w/shop
Posted on Apr 29, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
My tv clicks to come on but no sound no picture
If there was a power outage the problem is likely in the power supply.
The power light on the front comes on or not?
If no power light unplug the set and follow power cord inside and check the fuses---the click is a power relay activating---set may have up to 3 black relays on the power board.
Let me know your skill level and I will be happy to help.
SD TECH
Jan 16, 2012 | Hitachi 57F500 57" Rear Projection...
Once the current went out in our residence, the tv went out as well. When the current was restored, the tv didn't come back on by the remote or pushing the power button on the tv itself. Where the green...
Although you may think the power outage has ruined your TV, it has not. I have repaired this model . This model by now has several bad grounds. The worst case is in your convergence board. This problem was in the process before the power outage. I do not believe you will have to purchase parts for this particular model. If you can very carefully pull out the convergence board, you will find 15 or twenty bad solder grounds on the solder side of this board. The major concern will be that the convergence IC, which is a STK-393-110 has separated pins from the board. This would be the first thing to solder. Next the jumper jack cables that connect this board to the other two boards will have bad grounds as well. You must really,really have good eyes to see the cracked rings around the pins of any and all ICs,resistors,transistors, capacitors, diodes etc. This will restore the operation of your TV. I must tell you...it will not be easy to pull this board out and replace. You may opt to see a TV tech. Show a tech this info. This will repair this TV. Thanks for asking and show a few hands of support!
Feb 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
No picture or sound
could be blown flyback transformer
Aug 22, 2009 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
