Sometimes I can get the tank clear of the robot and today it won't open. What am I doing wrong? Also I'm getting an error to check the brushes. I also can't figure out how to get to the brushes either. I've yet to even use the robot. I have a robot for the floor vacuum and love it.
    Top Expert:
  • Washing Mach... Master
  • 76,070 Answers
What is the make and model please.
Posted on Apr 17, 2009
  • yadayada
    yadayada Apr 17, 2009
    that should read model number and make
How do I clean the gear box?
By gear box do you mean the inside of Roomba or do you mean the latched brush section on the bottom? You can open the two latches and clean the brushes after taking them out. You can pop out the white/black ball wheel and clear the hair and thread that catches in there. You can unscrew the screw that holds the spinning white brushes and clear the stuff out of there. You can take out the filter compartment and remove all the screws to really clean that out. I started to open up the main compartment of Roomba to clean it out and stopped when it got more complicated. I know there's probably stuff in there, but so much gets caught on everywhere else that there's little left to get into the inner gearing, in my opinion.
May 18, 2014 | iRobot Roomba 560 Robotic Vacuum
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Grill won't get hot
If you recently ran the grill completely out of gas, sometimes it creates a vacuum of sorts in the regulator. Shut the grill off, refill the tank. Open the valve from the tank first, then go through your normal starting sequence. Should clear it up. Good luck
Aug 14, 2012 | Weber Genesis Silver B Grill
Error code 40, found problem, still wont start
you can disconnect the battery to clear the codes. If I remember correctly the code 40 is indicating an open injector circuit. You might want to check that area as well as the service manual for more detail
Nov 15, 2011 | Yamaha YZF-R6 Motorcycles
Makes clicking noise and runs for a couple of minutes and then says error 2 open roomba and clean brush cage-do that and the same thing happens 2 minutes later
Pet hair often gets sucked into the gear box that drives the brushes and can clog it enough to generate this error. you need to remove the CHM (cleaning head module) and open the gear box on it to clean it out... you can also visit iRobots site and buy a new one that has been redesigned to avoid this issue.
Cheers, immorion
ps check out robotreviews.com for super detailed walkthrough of this process.
Nov 27, 2010 | iRobot Roomba 560 Robotic Vacuum
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a iRobot Scooba Vacuum Received an error message to check brush. I cannot get into the tank. Lever will not release.
Press down on the silver tank saddle at the back of the robot. While putting pressure on the saddle, tap the release handle quickly, right at the edge. That should cause the tank to pop up.
~Fembot
Apr 18, 2009 | iRobot Scooba 380 Robotic Vacuum
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
