Question about Dell Dimension 4700C PC Desktop
Swap Dell 4700C Motherboard into New Case
My Dell Dimension 2400 motherboard died, leaving me in the lurch. A friend offered her Dimension 4700C, but the CD drive and network card on it are also defunct, and there aren't enough expansion slots/USB ports to plug in everything from the old computer. Is it possible/desirable to move the motherboard from the 4700C to the 2400? Any special tools or knowledge (other than avoiding static electricity) needed if it is possible?
  • 371 Answers
Let's make this really simple, though you are apparently knowledgeable enough to realize the answer,
without my intervention.
Knowing what we both know about the units and their present condition.
1. The 2400's board is dead.
2. The 4700C's network card and CD Drive (hence, the slots and/or inputs on the motherboard, and
therefore the motherboard are also dead.) I am willing to bet you that in another system, the network
card and CD actually work.
3. All Dell® system's are totally proprietary in the board design and even the placement and removal
procedures for all drives.
4. Neither system is state-of-the art, but you knew that also.
ergo
Since you know enough to protect for ESD I will take a shot and acknowledge that you could build from
a barebones kit a new unit, using any of the parts from the two systems that actually work and end up
with a brand new system that will work for you for an extended time period into the future.
s
with
Posted on Apr 17, 2009
    Genius:
  • 1,605 Answers
Yes and no.
yes you can swap the motherboard. it will fix but the bad news is you have to take everything from the 4700C. power supply. inclding the HD. the 4700c comes with SATA HD and the 2400 is IDE. if her HD still works then that is what you have otherwise, you have to re-install the operating system.
the 4700c should have 2 USB in the front and 5 USB in the rear. how many USB port do yu need?
  • 432 Answers
As long as the form factors are the same ie ATX then it should be fine - also ensure that cooling will be fine and that hardware wise it will all fit in then it should be fine if either of them are under warranty then I would check with Dell.
what things do you need to plug in as a network card only takes up one PCI slot, a dvd rw drive replacement is cheap and can either be IDE or SATA so dont see how that would take up extra space in terms of slots ?
If you need more IDE or SATA slots you can get another PCI card to support that / them.
Processors
The Processors should be inter-swappable, both system have a socket 478 on the motherboard.
Jul 01, 2012 | Dell Computers & Internet
My dell 2400 wil run for sometimes 10 sometimes 45 minutes and the the monitor loses signal and the power light is amber and the hard drive light is green, the diag. lights in the rear are either off or...
The power supply may be going out. Go to the Dell website, select support, enter your service tag number and find your symptom to determine the problem. The lights in the back will help you isolate the issue by cross referencing it to the lights that are lit and not lit.
Nov 02, 2010 | Dell Dimension 2400 PC Desktop
I have a dimension 2400. the current processor is a pentium 4 2.2 can i swap the processor with a intel core duo ??
After checking the specs of this here : http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
i can confirm that a intel core duo would not be supported without changing the motherboard, and probably the memory too.
Rytech Computer Services Limited
Oct 12, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 4700c pc clicks and beeps when trying to start up . does not start up.
  1. Generally this is a common problem of RAM.
  2. Check RAM, remove it, clean & install again. Restart your PC & check.
  3. Check the RAM with other PC for its healthyness.
  4. check all the connection of motherboard for tightness.
  5. Still not working then need to check the motherboard. it might be faulty
Aug 22, 2010 | Dell Dimension 4700C PC Desktop
What kind is motherbourd
The Dell Dimension 2400 motherboard is proprietary to the Dell Mitac Chassis. It should work in any Dell 2300/2350/2400/4600/4700 case. The main item is the Dell specific power/control panel connection. If you move the board take the control panel with it.
(Personally, it isn't worth the effort)
Jul 05, 2010 | Dell Dimension 2400 PC Desktop
How do i install a firewire card in my Dell Dimension 2400? What is required for me to do this?
can you look in the case if you can look at the motherboard if you have a pci slot free you should have no problem in putting a firewire card in
May 17, 2009 | Dell Dimension 2400 PC Desktop
I need a motherboard manual
Motherboard manual for this model is not available.
However you can download the full user manual here.
You find main info on motherboard and on diagnostic code in the manual.
Feb 24, 2009 | Dell Dimension 2400 PC Desktop
Does dell dimension 2400 have ethernet card inside?? Basically when dell made the dimension 2400, did the put an ethernet card inside. Or do i have to buy one and install it myself? I have this Broadcom...
The 10/100 Integrated controller is the onboard network card
That basically mean yes it does have a network card built onto the motherboard.
If this helped please leave a Rating
Best of luck
Blazamane.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 4700C PC Desktop Logo
597 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
