Question about EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA
DVD Drives not working
I have a G31T-M7 motherboard, duel core CPU, 1Gb RAM. 450W PSU
SATA HDD (250Gb).
SATA DVD-RW.
250Mb NVidea display card.
The problem is that the DVD drive worked for the first day, after that is still detects the DVD drive in the BIOS. the tray opens, but it does not read what's on the disk.
I then bought a normal IDE (LG) DVD-RW, this worked for 2 weeks and then had the same problem.
Then one day the SATA DVD drive worked again for about half a day.
I checked the jumper settings, removed the display and went back to the onboard display and removed the LG DVD drive, thinking the PSU can't handle it, but nothing seem to work.
Does anyone have any ideas for me besides chopping up the PC with an axe?
  • viviersw Apr 17, 2009
    The motherboard is a ECS Elitegroup.
    I got the BIOS update from the web site, updated the BIOS. The problem is still there. I have also changed the data as well as power cables, still the same problem. This should eliminate the PSU, I think, as the HDD works fine.
    Could the motherboard be faulty?
    Or could it be a jumper setting somewhere on the motherboard?
  • 432 Answers
Maybe a bios update and latest motherboard / chipset drivers ?
Also ensure that the sata and ide cable are seated firmly at both ends
what make is the motherboard ie asus etc ?
Posted on Apr 17, 2009
  • Shane Russell
    Shane Russell Apr 18, 2009
    I would check the bios to make sure that the settings are correct and that it detects the dvd drive and also check in device manager to see if it detects it.
    Maybe try the dvd drive on another computer if it works fine without the issues then its a motherboard or power supply issue - what wattage is the power supply and does it have enough wattage to power all the devices on your computer ?
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
How much power do I need for this board?
Power Supply Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
A) System Type: 1 physical CPU (Processor)
B) Motherboard: High-end desktop (KN1 Extreme)
C) CPU Brand: AMD
4) CPU Socket: Socket 939
5) CPU: Lord only knows. I chose a Processor that uses Up To 89 Watts. AMD Athlon 64 4000+ 2400MHz San Diego 1.35v
6) CPU Utilization TDP: 90% TDP (recommended)
(In otherwords leave alone)
7) Overclock my CPU!: Leave alone
8) RAM: 2 sticks of DDR SDRAM
9) Video Cards;
A) Video Brand: AMD (AMD owns ATI now)
B) Video Card 1: AMD Radeon HD5450
C) Video Card 2, 3, and 4: Leave alone
D) Video Type: Leave alone
E) Physics Processing Units: Leave alone
10) Hard Drives:
A) Regular SATA: 1 HDD
11) Go to Drives;
DVD-RW/DVD+RW Drive: 2 Drives
12) Go back up to the right; PCI Cards:
I left alone. Only you know at present, if you are using one, or more of these types of PCI cards.
13) Go to Fans;
80mm / Regular / 2 Fans. (Just guess-timating)
All fields should be entered now. If not make adjustments to what I didn't know. Include in the proper field.
Now go to the bottom right, and click on - Calculate
(Calculate / Reset / Print )
I come up with 265 Watts.
Want to know EXACTLY what hardware is used inside; without opening the computer case?
Use the tiny free program, CPU-Z from CPUID.com
(Can help you download, install, and use, CPU-Z if you need.
I have used CPU-Z for years)
http://www.cpuid.com/softwares/cpu-z.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | ECS KN1 EXTREME Socket 939/nFroce...
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
Asrock P4V8+ freezes after ram checking
Unless you are using 2 identical hdd's RAID should be disabled. This may be where the problem is as it's looking for a RAID setup where none exists. Enable SATA but keep the RAID set to either IDE or disabled. Then try rebooting. Hope this helps.
Jul 02, 2009 | Computers & Internet
Try going into the BIOS and selecting safe or minimal settings/options save and reboot. If this works go back to BIOS and make changes one at a time until it may not work again, then you will know which option is causing the system hang ups. My guess is also your motherboard is SATA 1 capable (1.5
gbs) not SATA 2, in which you could purchase a separate controlller card for your HDD. Good luck.
Jul 02, 2009 | Intel D865GBF Motherboard
Recently built a PC Power is On with No Display
Well depending on your bios version, it could be an array of things.
First try removing the video card and re-seating it.
Then re-seat the RAM.
If the problem persists re-seat the CPU.
Let us know the exact model of your motherboard so we can better troubleshoot your problem.
When you turn on your computer the system does a POST (Power On Self Test). If the POST sees an eror it will tell the BIOS (Basic Input Output System) and the BIOS will beep a code or display a code that indicated the problem.
Different motherboards contain different BIOS versions. BIOSes use different beep codes for problems depending on the manufacturer.
Mar 24, 2009 | Abit IN9 32X-MAX Motherboard
G31t-m7 motherboards can use inter Pd. 800 cpu
if your post code has completed so
heat problem or smps problem or ram problem or
remove all datacable exm : hdd ,writer,fdd and power on
Jan 16, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA Logo
156 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
