Sony KP-57WS510 57 in. Rear Projection HDTV Television
Problem for Sony KP-57WS510 57 in. Rear Projection HDTV Television
Auto focus and manual focus(red+will not move left
By daanders58 on Apr 17, 2009
my 57inch projection tv(sony) just went out of focus and flash focus and manual focus is not working. I cannot seem to get the red + to move left
Solution #1
posted on Apr 18, 2009
Not Rated)
Ecollier2012
Rank: Guru  Sony Televisions & Video  Expert
Rating: 93%, 681 votes
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-57WS510 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS510 57 in. Rear
Do you recommend Sony KP-57WS510 57 in. Rear Projection HDTV Television?
Answer
Answer
When I turn the TC off, I get a red circle in the center of the screen and then it slowly fades... (More)
Answer
how do I hook up WII to my bose surround,instead off my tv speakers
Answer
TV has worked well for seven years. Turned on today to find ghosting and bad color. Is this... (More)
Answer
I have a KP-57WS510 and can't get the convergence quite right. I have a blueish mark across the... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
