Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Microwave stopped working...
Several times before my microwave quit working, the fan would turn on when I opened the door. Now, when I try to cook something, I punch in the time and push start...it makes a click and nothing happens but the time starts counting down. The light goes on inside and it looks like it is working but there is no sound that anything could possibly be heating up in there. Any suggestions?
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
GE PVM1870DMWW
Check those 3 micro switches in the door latch assembly
Nov 15, 2017 | Microwave Ovens
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Just like others, the microwave component does not work. Convection works just fine. Before microwave quit, it appeared to have something to do with the door(?) I would put a napkin b/w door and by...
If the inside light, fan and turntable come on when you try to cook, but it does not heat, this is probably a bad primary interlock (top door switch) or possibly that switch's mount is bad.
See this file on safety, and this file on door switches.
We have the full service / installation manual for this unit, and have uploaded it here to help you.
If the inside light, fan and turntable do not come on when you try to cook, the 20A fuse is probably bad or loose in its holder.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Advantium SCA2000B Microwave Oven
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Sharp 1611
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
Oct 13, 2007 | Sharp R-1610 Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Only the keyboard is working
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, but it's usually a door switch.
Oct 03, 2006 | Danby DMW105 Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
178 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
