Question about Kenmore Washing Machines
How do you change the door lock
How do you change a door lock on a kenmore frot end loading mach. h3t# 11044936203
Removed the rubber seal on the base of the machine. then removed 3 screws from the outside of the door lock, unepluged the 3 connections. and replaced the locking mech. put the rubbed seal back in place. It took me only 20 min. to do with a little help with replacing the strap for the seal.
Posted on Apr 18, 2009
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
It displays a message: dl and stops
Possible causes: (power off the mains first before checking)
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU). The wires shd be secured well.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
May 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore HE3 washer water flows out of bottom
check your door seal first.,
take your kick panel off
3..... 7 millimeter screws or t15 torques
check your hoses
check your drain
more than likley it's your door seal
you can also take the lid off same way you took the kick panel off
let me know what you find
May 04, 2010 | Kenmore HE3T Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
After I paused my Kenmore H3t washer to add clothes, it will not
sounds like you may have a bad door switch or the door latch on the door is broken
Apr 02, 2009 | Kenmore Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
My kenmore washing maching door is not opening
Hold in "end of cycle" for 3 seconds. Or if you have a pic of a "key" on one of the buttons, hold that in till the lock signal goes off.
Feb 22, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore H3T washer
The following link explains the "FH" error in detail:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
You may still have a water inlet problem if the washer is not filling and the taps are turned on.
If the door is locked and you cannot get the door open, you can use this link on how to access the manual release:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
These problems may be attributed to a momentary glitch. Unplug the washer for 30 minutes and use the manual release to unlock the door. In many cases the problem(s) will clear. If the problems still persist, go to my profile and use the "Ask Me" feature for a quicker response to any questions you may have. I hope this helps you.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Dec 20, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
