Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD-T50W1 there appears to be cobwebs behind the front screen. How do i get rid of them???
Great solution............
Just wished i saw it BEFORE i removed the back panel and broke the mirror.
Posted on Feb 04, 2008
Thanks my friend ,, I have this TV long time a go and I have been thinking how to make it clear , it happen finaly bcs of you ,, you my best friend . thanks again
    Genius:
  • 1,694 Answers
Take the lower speaker grill cover in front off.Remove screws holding sreen frame on. slide screens to side to access cavity.Ask a pro or go slow!!be gentle and observant. remove webs with rag or feather duster.DO NOT spray any liquid.Dust RGB lens caps with soft cloth.Re-assemble.
Posted on Sep 24, 2007
No picture. Black screen. Have sound.
it have a bulb like halogen or spot light in projector tv, you can find that at the back cover!
Feb 14, 2010 | Televison & Video
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Removing the protective screen on our Pioneer SD-532HD5
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Nov 11, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Need new remote not sure were to buy one please can u help me nsw Pioneer Widescreen Rear Projection TV SD-T50W1
You can buy a universal remote in Radio Shack, Best Buys, Circuit City, etc. or any department or appliance store. A factory replacement remote is available from the manufacturer, Pioneer.
Mar 09, 2008 | Televison & Video
Cobweb?
You'll need to have the frame of the tv either opened so you can reach in there or the top mirror block assy will need to be removed to get inside to the screens. You may want to have a Sony ASC do this type of repair. Call Sony for a referral.
Dec 26, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
PIONEER SD-T50W1 VERTICAL PROBLEM
Usually, when a picture collapses some but not all the way, it indicates that an electrolytic capacitor has gone bad in the verrtical circuit. If the top of the picture shrinks, suspect the pump-up capacitor, but if the bottom shrinks then the coupling cap is probably going bad. This is quite an easy thing to correct, so have a qualified tech service the set.
Sep 01, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
237 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
