Whirlpool duet sport WFW8300SW F30 error. Have been removing detergent bin and rotating round piece in back (as per google troubleshooting suggestion). This seemed to give a temp. fix but now not working at all giving F30 error all the time. Any recommendations? Anywhere I can get a pdf manual to replace the needed part? Thank you for any help....I'm stymied.... Debbie
    Brigadier General:
  • 8,619 Answers
Hi!
Please remove the detergent drawer and reach to the top of back of drawer and check for a water diverter that may be stuck between an open and closed position. Turn it back to the closed position and then you will need to replace the drawer.
If this doesn't help then follow this procedure:--
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of the dispenser.
3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU).
4. Check dispenser motor for powered rotations. Please do accept this solution and revert for further assistance.
Thanks Rylee
Posted on Apr 17, 2009
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport f30
Get the top off there and check the mechanical arm on the dispenser motor. then check that motor. F-30 = dispenser failure.
DUET SPORT SERVICE MANUAL
Sep 24, 2012 | Whirlpool duet Washing Machines
My washer is giving me an error message of F30 and it makes humming noise like it wants to come on but it doesn't.
The fault guide says the following about F30:
DISPENSER SYSTEM ERROR
The dispenser motor cannot be driven to its proper position
1. Unplug and disconnect power
2. Check mechanical linkage from dispensor motor to top of dispenser
3. Check wire harness connections to the dispenser motor and central control unit
Hope this helps
Jul 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
I get F 24 when press start. please help.
F24 Water temp sensor error Failed sensor or heater.
Easy fix! Remove the panel and check the heater and thermistor at the base of the drum.
Here is the Hippy to show yall how to get in the machine
Duet sport error codes and manual are HERE
Dec 28, 2010 | Whirlpool WFW8300SW
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 continues to show on display.
Comunication error between motor control unit and Central control unit. Broken wire in the harness.
F01 power glitch: disconnect power for 2 mins verify correct CCU operation
F11 Motor control unit internal failure MCU board failure or broken wire.
F20 No water detected entering machine, pressure switch hose clogged
F21 Long drain Possible cause: Clogged filter, clogged/failed pump
F22 Door lock error Failed lock. corrosion,or broken wires.
F23 Heater Failure Bad heater
F25 Motor Tach error Bad MCU (motor control unit) or broken wire
F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
F27 Overflow condition Clogged drain, pump, kinked hose.
F28 Com error between MCU and CCU (central control unit) Broken wire
F29 Door unlock error bad switch,broken wire,corrosion
F30 Dispenser system error Bad or jammed motor, broken wire
F31 MCU failure due to motor overheating.
F33 Pump drive system error, broken wire, corrosion
rL (prewash)Clothes detect. Remove clothes and retry.
5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
For diagnostics and further info refer to this handy dandy:
DUET SERVICE MANUAL My tip:
http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
Mar 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Water pouring out of the detergent holder duet sport
you have an article of clothing stuck between the tubs. run your hand around between the tubs and you will probably find something at about the 11:00 o' clock position.
Jan 13, 2009 | Whirlpool WFW8300SW
Washing Machines Logo
216 people viewed this question
Top Washing Machines Experts
