Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printer continues to indicate "out of paper" even after reloading and pressing "ok".
  • two-eagles May 08, 2009
    It is my roller arm that will not lower to advance the paper into the printer. Anyone have a clue how the fix the roller arm ?
  • 14 Answers
Check the paper tray - there's a "stop" that keeps the paper snugly in the tray. Make sure this stop is set on the proper paper size and isn't sliding when you put the paper in. That should solve it!
Posted on Apr 17, 2009
The printer indicates out of page. Load paaper the press OK. I have paper loaded in the printer and only on the first page i will get the indicated out of page. Once I press OK the system the printer...
The pick up rollers are dirty. You need to clean them with a damp cloth. These rollers should be just above the leading edge of the paper when loaded.
Dec 23, 2010 | Office Equipment & Supplies
Although I have loaded my paper properly (i've been using this printer for over a year) it will not feed I get the error message that the paper is not loaded properly. I have tried to reload the paper and...
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
Nov 28, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Our printer keeps telling us to load paper, although all ready loaded and will not print. even after attempts at reloading then pressing ok or even resetting the machine. Please help, we need it to print!...
please your printer in dumping roll is currently warking if no then changing the dumping roll and dumping pad is add new and the printer select to defold printer is currently ok.
Oct 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Had a paper jam, fixed it. Now it won't print anything.
Follow these steps to resolve the paper jam. Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. This video supplements the instructions in this document. For best quality on dial-up connections, wait until the video has fully loaded before viewing. Flash Player from Macromedia is required to view this video. If needed, visit the Macromedia Web site (in English) to download and install Flash. Click here to go to the Macromedia Web site.
  1. On the rear of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Removing the rear access door c00442055.gif CAUTION: Do not try to clear a paper jam from the front of the product. Doing so can damage the print mechanism.
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears while being removed from the rollers, check the rollers and wheels for torn pieces of paper that might have remained inside the product. Loose pieces of paper will cause future paper jams.
  3. Replace the rear access door. Gently push the door forward until it snaps into place.
  4. Press OK to continue the current print job.
    • If the issue is not resolved , continue to the next step.
    • If the issue is resolved , you do not need to continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step three: Clean the rollers
  1. Turn off the unit, and then unplug the power cord.
  2. Press in the tab on the left side of the rear clean-out door to release the door. Remove the door by pulling it away from the unit.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Cleaning the paper rollers c00246512.jpg
  4. Allow the rollers to dry completely, and then replace the rear access door.
  5. Plug the unit back in and turn it on.
Step four: Clear the jam from the automatic document feeder (ADF)
  1. Lift the cover of the ADF. Figure 3: Lifting the ADF cover c01391962.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when being removed from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. Loose pieces of paper will cause future paper jams.
  3. Close the cover of the ADF.
Step five: Reload paper and test the All-in-One
  1. Reload plain, letter-size paper in the main tray.
  2. Press the Power button (c01324469.gif ) to turn the product on, if it is not already on.
  3. Press Setup .
  4. Press the right arrow button (c01185072.jpg ) until Print Report displays on the control panel, and then press OK .
  5. Press the right arrow button (c01185072.jpg ) until Self-Test Report displays on the control panel, and then press OK . The self-test prints.
Step six: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jul 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Paper in 3310 HP
You have a possible paper jam or foreign matter in your roller area or feeder area, get a torch and thoroughly check inside unit, near carriages, roller and paper feeder.
Aug 17, 2007 | HP Photosmart 3310 Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
