Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I am stuck on the rinse cycle. it wot allow me to set it to anything else including a normal wash. Have tried unplugging but its still only rinsing. Please help!
  • gem_hughes Apr 22, 2009
    same problem - have posted seperately too.
Unplug, remove tub by rextending out fully and uncliping lock tabs at front of slider. lift tub out and support on a chair. the circuit panel on bottom left floor area needs to be dried out underneath, there is a water sensor below this panel and if it gets wet it will produce f1 code. dry out and replace, then put all back together and plug in and try again. if not working try again,if no luck then call tech. hope this helps, worked for me.
Posted on May 02, 2009
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Need info about extra rinse cycye
there should be agitation..dont know unless its not making the connection in the control head..
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
WA37T26 rinse/spin cycle
if it is set on Eco it will do a lot of spray rinse cycles to save water.
Aug 15, 2017 | Fisher and Paykel WA37T26 Top Load...
Mu washing machine is getting stuck on the rinse cycle. There is no error code coming up, just all of the light blink with the exception of wash and spin. I have unplugged it overnight and it didn't help....
Look under it for a diagnostic manual
You got codes or something there if it blinks
May have a bad control board
Need that service manual to start your testing
Sep 13, 2013 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
227 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
