Question about Canon Cameras
Canon EOS Digital Rebel SLR Shutter Problem
More then half of picture is black - need to know how tofix it myself - do i need to order the shutter assembly part or can i fix whats already there??
  • 371 Answers
DNAR!
Stands for Do Not Attempt Repair.
First of all, you will void any warrantee by doing so, with or without technical expertise.
Without technical expertise you will ruin your camera, possibly making repair by a professional a least
cost remedy for your shutter's problem, whether in or out of warrantee, as you would then either be
deprived of the use of your camera, or have to buy a new one, at the regular retail cost.
Even a refurb would be a good option as the unit would have been serviced, and Canon has good bench
policies and is an advertiser on our site for their downloadable drivers, which assure you of the best possible
results.
First make sure that your drivers are up-to-date, and that is as far as you should go without professional
intervention.
Posted on Apr 17, 2009
  • chafamail Sep 16, 2010
    Answer not helpful for me. Repair costs as much as getting a new model. I need to know what it is.
    I am willing to spend less on a DIY than on a used one on ebay.
    Rebel DS6041
When i take a picture the top half is good but the bottom half is black
Are you using the flash? if so then the shutter speed is not synchronized with the flash if no flash is being used then the shutter may need replacement.
Apr 06, 2011 | Canon Digital Rebel / EOS-300D Digital...
Half of the picture is black on every picture.
If the affected photos were taken using a flash then you simply had the shutter speed set too high. The fastest shutter speed you may use when using flash is 1/90th of a second; with anything faster the second shutter curtain starts to travel across the film plane before the first one has fully crossed so only part of the negative is exposed.
If they were taken without flash then your camera has a faulty shutter assembly which must be replaced. It's not a DIY job, it's not cheap, and on a consumer grade 35mm SLR like any of the Rebel/EOS triple digit models it's usually not cost effective. Especially when there are millions of them lying unused and regularly available for next to nothing on auction websites and for absolutely nothing on FreeCycle/Freegle.
Please take a moment to rate my answer if your question has been resolved, or add a follow-up comment for me to reply to if my answer does not meet your needs.
Apr 14, 2010 | Canon EOS Rebel X 35mm SLR Camera
Cannon 35mm EOS Rebel X S Shutter Problem
problem in shutter clean the shutter with white petrol dry it no need of lubrecant
Sep 09, 2009 | Canon EOS Rebel XS 35mm SLR Camera
My Canon EOS Rebel 35mm SLR camera seems to be giving random pictures which are black half way down from the top. What can cause this?
One of the shutter blades is faulty or is being obstructed. Either that or you're using flash to take pictures but using too fast a shutter speed, most SLR's have a flash synch speed of 1/60 or 1/125 of a second.
The first problem will need a professional repair, but it may be a fairly straightforward one. The second problem would require that you read the user manual for both the camera and flashgun.
Jul 01, 2009 | Canon EOS Rebel G 35mm SLR Camera
Canon EOS Rebel S taking bad pictures
Your camera has a faulty shutter or shutter timer.
Given that you can buy a perfectly good Rebel S for anywhere between £1 to £25 on Ebay it's not economical to repair it.
Jul 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Shutter problems?
You set the shutter speed at 90 when you are using with flash.If you set 125, then half frame would come
Mar 04, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
Digital rebel / SLR photos are nearly all black
If the camera still "operates normally" with recorded pictures while they are all black, you try to select CMOS Cleaning to see if the shutter really opens or not. If not, a plastic lever operates the first set of curtains had broken. This could be common for all plastic shutter except EOS 1 series which use metal.
Sep 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
216 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
