Question about Bernina Virtuosa 160
White thread stitches appear dirty grey
I run the zig-zag stich to do applique. My white thread is coming out a dirty grey and black. I thought this was oil/dirt in the machine so I cleaned it as best I could. I then took it to be serviced and cleaned and it came back even worse. There is black dirt coming out all over the stiching.
The machine is a Bernina Virtuosa 160
  • Tania Perelberg
    Tania Perelberg Jan 08, 2014
    I have the same problem. Were you able to find a solution ?
  • 19 Answers
Is this the top thread or your bobbin thread? The technician should have pulled out the tension disk assembly and cleaned it, not just spray more lubricant/cleaner on it. Is this a Bernina certified shop?! Take it back and get him to do it again right, it sounds like carbon/dirt build up in the disks. Have him pull the assembly apart and make sure it's not something else wrong with the disks themselves like oxidization etc.
If it's your bobbin thread.. your bobbin case is just dirty and the spring needs to be cleaned.
The thread doesn't really touch any other parts of the machine, hopefully your technician isn't using grease as this just causes more headaches for attracting more lint and then dirt.
Posted on Apr 17, 2009
  • 202 Answers
It can only be coming from somewhere in the thread path. This could also be coming from below the needle plate. Clean everything with a q-tip real well. Take the hook out and clean below the needle plate from undernieth. A common placed missed.
Rick
Posted on Apr 21, 2009
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Brother Sewing Machines
How to applique with my Quilters Dream sewing machine
You should practice on scrap fabric until you can get the technique down well. There are different kinds of applique.
To cover raw fabric edges, you can do a smooth line of zig-zag over the fabric edge. Set the stitch width to a wide stitch and shorten the stitch length until the thread lays nicely next to each other with no gaps of fabric showing but also not so close that the stitches are on top of each other. There are methods for turning corners or curves that are nice for making a great looking edge.
Some tutorials may be helpful.
How to Applique
How to Do Applique How to Make and Apply Appliques
How to Appliqu Like Pro Sew4Home
Sep 05, 2016 | Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Apr 19, 2011 | Juki MO-644D Mechanical Sewing Machine
I don't know how to make satin stich Janome DC2010
As a general rule of thumb, satin stitch is obtained by selecting zig-zag, turning stitch width up to 3 or 4 and stitch length to 0.5. If you have a clear plastic open toe sewing foot, put that on to help view the area.
If you are doing applique (attaching pieces of fabric to another surface) with a satin stitch, you may also need to use tear away stabiliser underneath or interface the fabric first, it depends on what/where you are doing the satin stitch onto.
And a nice machine embroidery thread will give you a much silkier appearance than plain thread.
Mar 13, 2011 | Sewing Machines
Sewing Machines Logo
792 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
