Question about Garden
Lawnmower runs eratic
I have a Honda GVC160 mower,I have drained the tank, put new gas in but it's hard starting. It is designed to run at full rpm. I sprayed some quick-start in the carb,and it started but it ran up & down on the rpm., could there be a fuel filter in the tank? thanks
  • 38 Answers
No, there is no fuel filter in the tank. However, what you want to do is take apart the carb and clean everything with carb cleaner. Pay special attention to the needle and seet
Posted on Apr 17, 2009
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
My wife put diesel fuel in the gas tank trying to help me. I have drained all the fuel put new fuel filter on and it still will not start. I think there must be diesel in the carburetor bowl. Is it...
squirt some gas in the carb and start it up it will only run for a few secs so quickly keep squirting gas in ,but not to much as to flood it and that should burn the diesel out and shortly it should keep running
Jul 25, 2011 | Husqvarna Zero Turn Mower Z5426
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Honda push mower wont run right
Mar 24, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Mar 15, 2009 | Garden
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
