Question about Gateway T-1625 Notebook
Gateway T-1625 overheating
After my laptop has been on for less than 30 minutes, the fan starts blowing heat air. It just gets hotter though out the day. My machine is only about a year old.
  • 2 more comments
  • amberw30 Apr 24, 2010
    my laptop is over heating really fast and frys my hard drive and it will shut off the comeputer.
  • blueextc3221
    blueextc3221 May 11, 2010
    thats the purpose of the fan - to disperse hot air.
    your laptop is functioning normally.
    as the workload increases - the heat increases - and the van kicks in at variable speeds to save battery charge.
  • i_am_the4win
    i_am_the4win Feb 10, 2013
    Try unscrewing the bottom and cleanin out the fan every once in a while. When I do, about every 3 months, I usually get about a winter coat worth of lint out. Cools down the fan immensly.
  • Martin Mar 31, 2013
    Clean cooling assm...Works great now. Thanks
  • 298 Answers
Get a can of compressed air, some dust may have accumulated in the heatsink causing it to overheat faster. Blow into the vents on the back or bottom of the laptop it should help.
Posted on Apr 17, 2009
  • Gateway Master
  • 5,660 Answers
Laptops have a poor cooling system.
All of the hardware components for a laptop are crammed into one tiny box.
Add to this that the Air Intake Duct for a laptop is either on the bottom, or side of a laptop.
This makes an excellent path for the 'inhaling' of foreign debris.
Dust, Dirt, Hair, Food crumbs, you name it, is readily sucked up.
The Air Intake Duct narrows down to a Cooling Tube. Makes a funnel effect. The Cooling Tube goes to a Heatsink, and there is a small fan on top of the heatsink.
As the foreign debris collects, the cooling capacity drops tremendously.
The Cooling Tube, Heatsink, and Fan clog up.
Using a can of compressed air for computers is an excellent suggestion. Break off the plastic tab on top of the can, insert the plastic 'straw'.
Remove the AC adapter, (Charger) if plugged in, and remove the battery.
There must be NO electricity to the laptop, when using the can of air!
Hold the laptop up on it's side, and blow air towards the Air Intake Duct. You do not want to blow air into the Exhaust Duct. Check before you start, as to which opening is the Air Intake Duct.
Start by bring the straw about a finger length away from the Air Intake Duct grille. Start at the top, and go across. Squeeze the trigger in all the way as you start, let go of the trigger once you reach the other side. It's just like you're spray painting.
Drop down a row, and go across again.
How far you drop down to make the next row is up to you. You'll have a pretty good idea, and it will be just fine.
Once you reach the bottom, go back up to the top. This time bring the plastic straw right up against the grille. Use Short Bursts now.
A Short Burst is squezzing the trigger in all the way, but letting go quick.
You want to use Short Bursts now, because the air pressure coming out of the can of air, can spin the small fan inside too fast.
It can spin the fan faster than it was designed for.
Spinning the fan faster than it was designed for, can lead to premature failure of the fan's bearings. The fan will quit before it's time.
Once you're satisfied that the Air Intake Duct is clean, I invite you to set the side edge of the laptop up on a book. Let it sit for ten minutes. This gives it time to dry out in case any of the propellant came out of the can of air.
Now reinsert the battery first, then attach the AC adapter.
When using the can of air for a bit, you'll notice it seems to slow down in air pressure. This is because the air is coming out so fast, that the moisture in the outside air freezes. You'll notice frost develops on the outside/top of the can.
Just let the can of air sit for about ten minutes, then you can pick it up, and continue. This gives the can of air a chance to warm up.
I advise you to keep the laptop on a flat hard surface when using it.
I know it's a -> Laptop, but your clothes, bed coverings, etc, can block the Air Intake Duct.
I would also like to suggest that you look into getting a Cooling Pad.
This helps to keep the laptop cool, and is a flat hard surface.
Cooling Pads have fans in them. There are types that use battery power, or plug into the laptop, or types that plug into a surge protector.
There are expensive Cooling Pads, and inexpensive Cooling Pads. An inexpensive will do the job just fine.
Here are examples,
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000260319%201276817102&name=Cooler
    Scholar:
  • 195 Answers
I got this laptop from someone because it had died and he had replaced it and no longer wanted it. I found the hard drive was DOA so I replaced it. I installed Windows and soon found out that the laptop would overheat and shut off. I tried cooling pads and made sure the cooler was free of dust and debris, to no avail. Finally I removed the heat-sink/fan assembly to see if there was good contact to the CPU. The thermal compound was rock-hard and brittle and either cracked when I removed the unit, or was cracked already. I suspect that it had cracked some time ago and that was the cause of the overheat I carefully removed the thermal glue and polished up the base of the heat-sink. I also removed the putty-like pad that contacts the AMD chipset to the cooler. I then used Arctic Silver thermal compound, somewhat copiously applied, and refit the heatsink/fan assembly. So far the system runs perfectly, and the laptop feels considerably cooler than it did. I believe that a large number of these laptops suffer exactly the same issue. I looked long and hard for a solution to this and did not really find any help, so I'm taking the time to chime in with the hope it will help someone.
Pied
Posted on Dec 03, 2011
  • Steve Hallett
    Steve Hallett Feb 14, 2013
    Over a year later and that little laptop is still chugging away : )
How to clean a laptop fan
Gateway laptops can overheat just like any other computer brands. It is natural for laptops to heat during use. However, Gateway laptops that overheat can be the result of dust within the computer's internal components, fan faliure or frequent multi-tasking by the user (going back and forth from one window or program to the next). The laptops can overheat the central processing unit (CPU) which can run the risk of damaging the computer's motherboard, video card and memory.
Check the Gateway's PC Health status to view the current temperature settings under the computer's BIOS menu. According to Gateway, "the temperature is usually displayed in degrees Celsius. Faster processors and those with larger onboard L2 cache memory s tend to run hotter than slower processor and those with smaller L2 memory caches." Make sure that the CPU temperatures is no more than 50-55 Celsius. If it is higher than 55 Celsius, then the laptop's internal components should be cleaned. Open up the laptop to fix the fan. First, turn off the laptop and unplug the AC adapter. Turn the laptop over to expose the battery compartment. Unscrew the battery compartment with a small Philips screwdriver to internal fan. Free the fan of dust. According to The Washington Post, "hit the fan in short bursts from lots of different angles, making sure to blow most frequently in the direction of the air vent." Use an air compressor on low to blow out the dust. Caution getting the air compressor too close to the fan as it can damage the computer's internal components. Disassemble and clean up clogged air vents with a dry rag if you have more experience with computer components (do not attempt to dissemble air vents with out prior experience). Read the Gateway laptop user's manual for proper procedure instructions on cleaning out the computer's air vents. (or contact a Gateway service representative to help walk you through the process). How to avoid overheating http://www.hardwaresecrets.com/article/142 Gateway troubleshoot cpu overheating
http://support.gateway.com/s/tutorials/Tu_949700.shtml How to fix a noisy laptop fan (Gateway M-2626u) http://www.youtube.com/watch?v=8d3GrNqnhYg
This might not be your specific laptop it might give some insight in to how to clean gateway fan
Feb 26, 2013 | Gateway nv5105u Notebook
Overheating?
you can buy a cooling pad or try cleaning your fan or a heat sink
or change your fan and heat sink
May 19, 2010 | Gateway MT3705 Notebook
Gateway m 1625 operating system not found and its overheating
This means either the operating system on your hard drive has become corrupt and you will need to reinstall your operating system or, more likely, your hard drive has failed and you will need to replace the hard drive and the operating system.
As for your heat issue, use a can of compressed air and blow out all the vents on your laptop. This should help the heat issue; note that it is common for the laptop to feel hot as it is dissipating the heat from inside.
Thanks and please take a moment to give this solution a thumbs up rating with a solved solution as I answered your questions. Thanks.!
Apr 05, 2009 | Gateway T-1625 Notebook
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
Laptop overheating
Concur Wayne.
LaptopExpert is exactly right in his diagnosis and all aspects of his solution.
Well done people
Nov 17, 2008 | Gateway 450ROG Notebook
Over heating
Hi, does the battery last as it was earlier, before starts over heating?. If not, you are having some hardware related trouble and you need servicing of the system, else cleaning the fan and air vent may solve the problem.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Gateway T-1625 Notebook Logo
1,856 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
