Epson TM-U220 Matrix Printer Logo
Posted on Sep 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson tm-u210pd paper alignment problem
When i m printing from plexis POS,paper is no aligned correctly.it uses two paper for carbon copy process.these two papers not correctly aligned.paper type used is is "reserved 48".
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Feb 12, 2008
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
64132
Points
121
Actually, the issue that you are having is with the paper, try changing the paper and use epson.
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Drivers epson m119d windows 7
try at
https://download.epson-biz.com/modules/pos/index.php?page=single_soft&cid=5736&pcat=5&pid=40
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
http://pos.epson.com/products/TM-U220.htm
http://pos.epson.com/developers/index.htm
6helpful
Cant print continuosly in epson lq300+
Sounds as if the format is wrong. You must set the paper format in the PC wordprocessor or invoicing software to the same size as the actual paper size of the invoice.
2helpful
2answers
Needed winxpdriver tm-u210pd
reinstall its driver from its disk or epsons site
2answers
Receipts
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
EPSON TM U200 POS PRINTER
try a self test print(hold feed and power up) if the printer still does not print check the ribbon to make sure it is inserted correctly. If it is still does not print it could be the printhead or pressure setting. you could also try printing with carbon paper to see if the pins in the printhead are striking the paper.
if the printer is still not marking the paper you may need to replace the printhead or printhead cable.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
