Question about Microsoft Wireless IntelliMouse Explorer
Does not work
I have a Microsoft IntelligMouse Explorer 2.0. Two days ago the mouse froze a few times and I would reinsert the batteries and it would be just fine. Today the mouse won't work at all. Installed fresh batteries, and rebooted computer, but the pointer is frozen in place. Plugged corded mouse in and updated drivers on wireless mouse, rebooted and pointer still frozen in place. When the wireless mouse is on, the light under it does not appear as bright and stays steady, if you run your finger over it, the light becomes brighter and blinks a few times and then goes back to not as bright. Is my mouse dead and needs to be replaced...or is there another problem.
  • Anonymous Feb 13, 2008
    Mine has done this too, and it caused my PC a -major- error to occur, resulting in a total rebuild of my PC. now the same symptoms as last time are occuring again. Help?
    P.s I hit it, and it now works. don't try yourself, it must have been a fluke.
I'm sorry you had to waste your time talking to me...lol. I called microsoft and the technican told me to push the button on the reciever and wait for it to blink..then push the button on the mouse and hold for 10 seconds. The mouse began to work. I don't think I have a instruction manual, for sure this would have been in it. I wanted to write back for others to know and to thank you, Benimur, for taking the time to help me.
Posted on Sep 17, 2007
    Brigadier General:
  • 6,966 Answers
Hi, The only easy user action I can suggest is to clean/check the battery terminals. In some instances, they get corroded and therefore will not provide good contact with the battery. You not only have to wipe it clean (with a solvent) but to actually scrape off to ensure shiny/corrosion-free terminals. It is also possible to bend it slightly towards the battery to add pressure to the contacts. The other check/repair is to open the mouse and check for any cold solder joints. The battery terminals themselves often get cold solder contact to the circuit board. It is very rare but some components do fail. You need to be familiar with electronic diagnosis, soldering with a low wattage soldering iron and possibly the use of a continuity tester to be able to perform this side of the diagnosis/repair. Your best bet is to seek the assistance of an electronics tech/friend. It may not be economically reasonable to have a qualified professional do service on the mouse. Hope this be of some help/idea. Post back how things turn up or should you require further information. Good luck and kind regards.
SOURCE:
Microsoft Wireless Laser Mouse 7000 'sticking' issue
You did not say what type of surfaces you tried. For example, a laser mouse with no ball in it, will not ever work right on a glass table top. And texture has nothing to do with it either, so putting a pure white sheet of paper under it won't help either. The best is to find something with a nice fine pattern on it. Something rough works better than something smooth, but only because texture indirectly causes a dark pattern.
Jan 01, 2010 | Microsoft Wireless Laser Desktop 7000...
How can I turn off this mouse?
dear sir
good day
Snap-in Mini Transceiver for Portability Simply snap in the transceiver to turn off the mouse, saving battery life. and for far info refare to the web page
http://uk.insight.com/p/MSJA061AC/microsoft-explorer-mini-mouse.html
thank you
Dec 24, 2009 | Microsoft Standard Wireless Optical Mouse
Spyder won't respond
try cleaning the laser of the mouse. the light spot at the bottom it mite have some dirt or something on it thats not alowing it to have a good conection
Dec 14, 2009 | AVENUES The SPYDER SwissGear Wireless...
Couldn't find the answer to the right click mouse button not working.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 16, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless mouse not functioning
If I rap the mouse on the desk a couple of times, it then works.
Sort of like Fonzi.
Jul 29, 2008 | Microsoft Wireless Notebook Optical Mouse...
Startup hangup
Try upgrading the firmware.
Mar 10, 2008 | Sony Ericsson P990i Smartphone
Wireless mouse quit working
plz check the batteries of your wireless mouse. try reinserting them or may be you can try a new set of batteries.also try to reset the connection on your mouse by pressing the connect button under the mouse and on the reciever together and releasing both together
Jan 21, 2008 | Computers & Internet
Microsoft Wireless IntelliMouse Explorer Logo
143 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
