Question about NEC MobilePro 900 Handheld
I cannot get my nec mobile pro 900 to sync with my laptop i downloaded activesync from: http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76 i downloaded the driver for mobilpro from here: ftp://ftp.necsam.com/pub/MobilePro/900/WinXP_MP90-USB.exe i followed the instructions on installing the driver. when i power on my mobile pro my laptop says: USB device not recognized. i have been able to make this work before, but it comes and goes. now it won't work at all.
Which one did you do first: Did you install ActiveSync 4.5 first, or did you try installing the driver first?
The best way to do this is as follows:
  1. Download and install ActiveSync (4.5 is what i use both at home and work and it works great with the NEC 900 and 900C's.
  2. Restart your Windows XP Machine (I assume you don't have Vista)
  3. Next, follow the instructions for the installing the NEC 900 usb drivers (these drivers should be installed AFTER installing ActiveSync... (it seems to work that way without problems for me).
  4. Next, restart your xp machine again.
  5. Now, connect your NEC MobilePro 900 to your Windows XP machine, and it should perform smoothly.
If this does not work for you, you can contact the folks at usedhandhelds.com, they sell and repair, as well as provide support for these machines.
Hope this helps
Posted on May 12, 2009
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Mobile pro 900
http://foro.todopocketpc.com/showthread.php?t=169252
Sep 28, 2008 | NEC MobilePro 900 Handheld
Sync probl
Windows Vista is a nuisance, in my own experience.
it has too many issues with drivers et,c.
i,d suggest seeking the setup cd, that would have been packaged with your Hand-held, Or PDA.
This would have had various Applications on it. And Also Active-Sync 3.5. However Vista. Will probably run or use Active-Sync 4.0. which is available from M$ Site. if you download from a computer running Windows 2000 Or XP. then put onto a memory card, or burn to a CD. that you can then install onto your PC.
Long-term, i,d suggest Considering XP. as a more stable and reliable Operating System.
Hope this Helps.
Mike @ Compurepair.
Jul 23, 2008 | NEC MobilePro 900 Handheld
Active sync
Do you have the proper drivers installed? Try here for USB to Computer Drivers if you have Windows XP: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip Also make sure that you have Activesync 3.8 or other version of 3. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Feb 26, 2008 | NEC MobilePro 900c Pocket PC
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Nec Mobile Pro 900c stuck
do a hard reset by removing the backup battery and main batteries. replug them and hold the power button for 10 seconds
Dec 30, 2007 | NEC MobilePro 900 Handheld
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
Mobile Pro 900
Maybe you can try disassembling it and see if it's damaged.
Heres a repair guide with images:
http://www.hpcnec.com/cgi-bin/simpleforum.cgi?fid=12&topic_id=1143848182
Dec 10, 2007 | Computers & Internet
My NEC MP900 won't sync!
First when you plug it with your PC.. do you hear the sound of the connection ? ... can you see the USB Icon at the system tray? Doest the system pop-up a message saying that the USB device isn't recognized? If it doesn't ! then there is no USB connection made... Try live support.. it's better to solve problems.
May 02, 2007 | NEC MobilePro 900 Handheld
NEC MobilePro 900 Handheld Logo
1,271 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
