Question about Panasonic DMRES15 DVD Recorder
Disc Not reading
When I insert a disc into my machine and close the tray my recorder beeps 5 times then goes into read mode on screen before beeping 5 more times.After this appears a message on the tv screen "cannot read please check the disc" then on the machines window comes A4 withthe small disc symbol indicating ready to play/record.When play/record button is pushed it begins over again.Machine is approx.12 months old and has performed flawless until now. Thanks. Merrybuss
  • 11 more comments
  • Tillan Jan 12, 2008
    Same problem.
  • Gareth Walker Jan 25, 2008
    Very similar problem here as well also without the A4 just says NoREAD.
    It started as crashing during recording then refused ram disc now won't even take pre-recorded discs...... Think the laser has gone down I also have an older machine that is starting to do the same... Think it may be a weakness.
  • claybries1 Feb 12, 2008
    Same problem as Merrybuss.
    Unit will or cannot read the disc
  • wishiknewall Mar 01, 2008
    Same problem as everyone else. All of the sudden my great machine just won't read. It was working perfect 15 minutes prior...Please help!
  • Anonymous Mar 03, 2008
    same thing, here.
    used quick record and it stopped after about 3 minutes and now it won't read any disc.
    same beeps and same error message.
    what about a reflash with the DVD i made for it's firmware upgrade?
  • youngey May 26, 2008
    exactly same problem as merrybus while disc loaded icon shows even when no disc in dvd recorder
  • arkhill May 29, 2008
    Our recorder says the same after a few clicks then 'cannot read disc'
    I tried factory reset but all that happened is that the screen is now all in grey!!!
  • Anonymous Jun 02, 2008
    exactly the same as merrybuss's problem
  • Anonymous Jun 06, 2008
    having same problem here also
  • vjr830r5 Jun 07, 2008
    remote no longer shows delete and playback on tv screen and will not read any ram disk
  • SimonBlue Jul 27, 2008
    I have a magnavox dvd player mpd845
    and sometimes it will play the movie other times it says loading disc and never plays the movie what can I do???
  • tarman1 Aug 26, 2008
    Exact same problem on DMRS15 as merrybuss- put in any disc - it clicks exactly 5 times and then No Read. and my DVDR is only 5 months old! did anyone find a solution to this?
  • Anonymous Dec 19, 2008
    exactly the same problem
Mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Posted on Jan 14, 2008
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
I can't record with my DVD player on 1x-16x DVDs
This unit is too old and too basic to handle 16x speed. However, there is a firmware update for this model DVD/VCR to record on 8x.
All you have to do is call the toll-free number in your manual and request it. They will send you an update disc.
Here is the basic procedure after you receive the update disc:
1. Turn on your TV and your combo unit. The tray should be closed. The unit must be in DVD mode.
2. Quickly press the sequence CM Skip, 6, 5, 4 (This will switch it into firmware update mode. The tray will eject automatically.)
3. Insert the disc and push the tray back in.
4. The update will begin. It will take approx. 2-3 minutes. It will tell you when it is complete and eject the tray.
5. When it is done, remove the disc, but DO NOT close the tray. It will go back in later. Turn the power off.
6. Wait a few minutes and when the tray goes back in wait about another 10 seconds and then you may turn the unit back on.
Firmware update procedure is now completed.
Sep 11, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Panasonic dmr-eh75v dvd won't work
dirty lens, broken ribbon connections or adjust the bias of the lens place at the back of the lens.....
May 08, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMRES15 DVD Recorder Logo
262 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
